Tube Adapters - diyAudio
Old 5th January 2017, 04:37 PM   #1
Default Tube Adapters
Does anyone here make tube adapters? I want to try some different tubes.
Old 5th January 2017, 04:43 PM   #2
If you are more specific, you will get better answers.
What device will you be putting the tubes into?
Schematic?
What tubes do you want to 'interchange'?
etc....
Old 5th January 2017, 05:01 PM   #3
OK I have two options, my pre amp use 6sn7 tubes in the line stage. I am using two 6f8g tubes with adapters there, I want to try the 6j5g tubes there. Also my amp SET 45 uses two 6sn7 tubes but, it only uses half of each one the other half goes to ground. I would like to try the 6j5g tubes there as well.
Old 5th January 2017, 05:24 PM   #4
There is a guy on eBay that sells an adapter for two 6j5g tubes to a 6sn7, problem is he is in Hong Kong.
Old 5th January 2017, 05:26 PM   #5
kaputt is offline kaputt  Germany
I make tube adapters for myself. But I am in Germany und get the parts from China.
You can easily make them yourself.
I like "effects boxes". As long as the effect is the right one.
Old 5th January 2017, 05:33 PM   #6
OK I can solder but don't know exactly what I need or where to get it?
Old 5th January 2017, 05:34 PM   #7
kevinkr's Avatar
I purchase stuff on eBay from China and Hong Kong all the time, China Mail is very reliable and depending on the service chosen items can be here in a few days, worst case a couple of weeks.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 5th January 2017, 05:37 PM   #8
Kaputt:
Sockets are easy to find, but I have difficulty finding tube bases.
Where do you get yours?
Thanks!
Do you have any 'construction hints'? I usually solder the connections and then use epoxy for 'mechanical strength'. Do you use plastic tube to join the base and socket?
Old 5th January 2017, 05:49 PM   #9
OK if I want to make an adapter to go from a 6sn7 to a 6j5g, that is 6sn7 on bottom what exactly do I need?
Old 5th January 2017, 05:54 PM   #10
kevinkr's Avatar
Old or new octal tube base and an octal socket.
Tube Amp Cap Adapters craigtone Swap Meet 0 6th August 2015 06:24 PM
Horn adapters Zene Gillette Multi-Way 9 8th September 2012 03:55 PM
surface mount adapters audioferret Parts 2 30th November 2005 09:38 PM
3 - AD825 adapters mattjk Swap Meet 0 9th March 2005 11:15 PM
Surfboards adapters carlmart Solid State 2 29th March 2003 11:25 PM
Copyright 1999-2017 diyAudio
