You need to work logically from source to loads. Power up the mains transformer in isolation from the amplifier, all secondary windings disconnected. Does it pop the fuse? If not reconnect the secondary windings one by one and power them up on each reconnection. Hopefully you will find which area of the amplifier is at fault.
Once you have the area at fault it's just a matter of elimination.
Eventually you will find the problem.
Circuit diagram would make this easier, but not impossible without it.
Regards, Aleks
Regards, Aleks
what is your line voltage and what size fuse are you using?
you can disconnect all secondary power traffo connections,
then test it again and see if the fuse pops...
what is your power traffo primary set to? if it is set to 120
and then you were tyring to load it 240, then fuses will surely pop...
thanks,, they are set up for 240 (I have used them for 6 months)
fuse 1.6amp (as per label on amp, secondary disconnected, 520 volts fuse ok
with ht insulated ,,valves in' heater also ok..
with transformer out off amp, no short to earth on ht, bias or heater
Check the Rdc of transformer (primary and secondary) on both amps without tubes.
Maybe you have one issue on it
Walter
RDC ?short term for
pk, so next step is to reconnect the psu one rectifier at a time....
vtl tt25
SORRY for slow reply !! with the ht onl,y powers up ok, with bias only also
ok ,with both connected (transformer out off amp, clip leads) pop !
I've taken the transformer out of the working amp, that will power up
both amps, the faulty transformer ( not connected) 520 v ht ,30v bias, 7.5
heater ,, with dmm shows no faults, I presume the trans has a shorted turn
ht to bias ,?
ht to bias ,?
ht to bias ,?
then better check downstream....
- Tubes / Valves
- VTL tt25
