Transformer Taking a Fall - diyAudio
Old 23rd December 2016, 06:40 PM   #1
Default Transformer Taking a Fall
Hello all,
It's been sometime since I posted anything.
Anyway, I Dropped a large 1930's transformer that is 1050VCT, so 525V with full wave rectification. It is an open laminatation with two end bells...about 4" log
The laminations one one side shifted about down 1/16" - 1/8".
Would this still be safe to use? Or is it risky due to the epoxy/ tar moving inside?
Any comments are appreciated.
Old 23rd December 2016, 06:57 PM   #2
Miles Prower's Avatar
Maybe yes; maybe no.
First, see if there is any continuity between the coils and core. If there is, it's no good. Test it by connecting a light bulb (one of the old fashioned kinds, not a CFL!) in series with the primary and power up with the secondar(ies)y open.If it hums, pulls excessive current, smokes, goes up in flames, then it's no longer any good. Strip it down, save the lamms and rewind.
If the current draw is light, just the inductive load current + core losses, then it should be OK. Next, try it with the full primary voltage applied and see if it still draws just small currents, and doesn't hum, smoke, explode, or get excessively hot. If it does any of those things, see above.
Side note: There may be some slight hum from loose lamms, but that's just annoying. Tightening the screws should stop lamm vibration.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 26th December 2016, 10:07 PM   #3
Thank you Miles.
I did everything you said.
Everything checks out... though I measured almost 300Ma draw on the primary with no load. This is a large transformer with 1050VCT with a 300Ma draw along with 5V and 6V taps. So the losses may be normal for a 1030's transformer.
Thanky= you for all your help and contributions to this site.
Roger
Old 28th December 2016, 12:22 AM   #4
TonyTecson's Avatar
power soak that with no load for about 20 minutes and see how warm the cores get...
if that were mine, i will dunk it in a vat of air drying electrical varnish. i will loosen the
bolts and nuts, remove the end covers...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 16th January 2017, 01:02 AM   #5
Will do.
I just realized I said "normal for a 1030's transformer"... I meant a "1930's" transformer... over 76 years old.
Maybe my concern is unfounded... but a 76yr. old transformer seems like it could damage easily with older materials being used vs. modern epoxies.
On the other hand... much of the old stuff has passed the tests of time.
Old 16th January 2017, 03:20 AM   #6
TonyTecson's Avatar
just be careful when handling, it sure can use a varnish bath....
you can use wooden or rubber mallets to align the core....
Old 16th January 2017, 05:46 AM   #7
trobbins's Avatar
You may be able to borrow an insulation resistance megohm meter. I got a digital one pretty cheap off ebay, and use it to test all restored amp transformer/choke insulation (1kV is available for mains testing), and also coupling cap and old switch leakage, and even if MOV's are still functioning.
Electricians pretty much have to check all AC mains wiring with that device when installing new circuits.
The outcome is similar to the lightbulb test using AC mains input, and earthing core and secondary, but it is also gauges how leakage current is flowing. Old vintage transformers will typically show more leakage than a modern transformer, due to the type of insulation material, and moisture and pollution ingress over decades.
Fall clean-out sale cygnus x1 Swap Meet 47 3rd April 2015 11:12 AM
Cyrus 2 no output after short fall WNR Solid State 9 24th December 2012 01:14 PM
DIY Ottawa Fall Meet mwmkravchenko Everything Else 34 4th November 2010 12:04 PM
Where do we most often fall short with amps? walker Solid State 87 6th September 2010 06:49 PM
US dollar fall ash_dac The Lounge 1 31st October 2007 12:22 PM
Copyright 1999-2017 diyAudio
