A power FET normally has the drain-source diode inherent in it. The existing zener acts in both directions, so no concern there.
The only concern is to add some current limit protection in case a screen fails short. Something as simple as a 3V/0.15A = 22 ohm source resistor may suffice. That may also reduce SOA stress at turn-on.
You would also need to check that input ripple at max loading does not cause the regulator to loose regulation from low input to output voltage differential.
