As long as DC + AC current is still above zero, then diode is conducting. Anode current can fly around (ie. not just sit on a straight load-line), but as far as I can appreciate it doesn't go negative. I can't yet rationalise when or how the screen current could go negative (and hence be influenced by a diode).
Putting a diode here is complete nonsense. If the screen current stays positive (as it nearly always will) the diode does nothing apart from dropping 0.7V, so a trival change in bias. If the screen current tries to go negative (which is possible with tetrodes, not sure about pentodes) then the diode will cause a massive change in bias and so huge distortion. So it either does nothing much, or it does massive harm.
You may sometimes see 'explanations' written by people who seem to believe that a diode passes DC but blocks AC (or is it the opposite?). Pure nonsense.
An others KBD-supporters from single-ended.com
http://www.single-ended.com/images4/KT90-EL156-KT88SE-standards.png
http://www.single-ended.com/images4/kt88-s.png
http://www.single-ended.com/images4/stopping-diode.png
I can´t find the KBD-sense.
...I think the sound is diferent....better..
I was sure that someone would soon say something like that
That is because it is nonsense.hego said:I can´t find the KBD-sense.
I take a chinoise EL34 SE kit and apply the controversial diodes and.... I think the sound is diferent: clear , flat, dinamic, powerfull....better.
I understand nothing.It hat no sense.
¿Suggestion?
The netx probe: take off the diabolic diodes.
This is stupid. I know.
TV Sweep tubes (using lower Vg2) can sometimes get operated too near to the grid 2 heating limits in designs that are pushing the limits. If grid2 wires get red hot, they could become an electron emitter toward the plate when the OT voltage swings up to 2X B+. So the diodes might prevent flashover and destruction in that case (no back conduction allowed).
Maybe those Chinese EL34 are running near grid2 meltdown. Might change the sound with some diodes then.
Could temporarily connect an LED across the diode in the reverse conduction direction (versus the diode). If the LED lights up at all with continuous audio signal applied, then some reverse current is flowing. (and possibly an alarm should sound!) There could be a -little- capacitive current that would flow from the wildly swinging plate V coupling to g2. (could show up with high frequency audio signals)
Yes of course. Sometimes people try to slip nonsense past other people by giving it a sensible-sounding name.
'Hego' needs to understand that asking a question, then answering it himself, and then arguing with people who offer a quite different answer is classic trolling behaviour.
- Tubes / Valves
- KBD - Kick Back Diode
