Old 12th March 2004, 12:23 AM   #1
zobsky is offline zobsky  India
zobsky's Avatar
Question How good are cheap tranny-interstages
Still researching on phase splitting options for my PP 6bg6 amp. I've read a few good cases for input phase splitter trannys and/or interstages.
the only thing that prevents me from using such things is .... COST , ... welll not cost in the pure sense, .. but the idea of using a $70- 100 phase splitter with a pair of $6 tubes and a $30 OPT. i may still go that way, .. but I'd like to investigate some more about alternative phase splitters which don't cost a lot of $$$ , ... just for the coolness factor
I've also been hearing some good things about the applicability of cheap (less than $10 ) edcor trannies run in parafeed as in the thread
http://www.audioasylum.com/scripts/t...ubediy&m=45954
I'm considering an edcor interstage in a parafeed arrangement to do double duty as a balanced pre-out and phase splitter. this arrangement is intended to power 6bg6 tubes in push pull. I was thinking of using a 5687 as the driver tube for each channel. basically a 2 stage parafeed coupled PP amp. No one's biting over there, so I'm asking for opinions here.
any opnions on how good this idea could potentially sound vs. more conventional tube based cathodyne /or long tailed phase splitters?
also, I notice a slight dip in the bass response of the interstage? could this be remedied by parafeed cap substitutions?
Any opinions on parafeed (DC blocking) IT vs. regular IT. I see a strong case made for parafeed here http://www.raleighaudio.com/chapter_2.htm .
thanks
"Any fool can know. The point is to understand" - Albert Einstein
Old 7th March 2012, 06:35 PM   #2
I'm really pleased with the Edcors in guitar amps. Havent listened to them in a HiFi amp tho, so cant say anything about their broadband fidelity. I've been meaning to try them in a HiFi amp, but havent had the time. They measure reasonably flat 20-20k.
Old 7th March 2012, 07:36 PM   #3
Globulator's Avatar
Holy thread resurrection Batman!
Is there any details online about Edcor interstage transformers?
Like ratios, impedances, prices etc?
good value (i.e. cheap) OPT in uk? adamus Tubes / Valves 6 11th November 2008 08:55 AM
cheap (230v 50hz) 160va 25+25 tranny on ebay guitar_joe Swap Meet 0 24th November 2007 10:53 PM
Musical Pre-amp topology needed. Interstages please apply! snaggs Tubes / Valves 1 13th August 2006 09:45 AM
Can you get a *good* cheap tube amp in HK? rick57 Parts 0 12th April 2005 04:10 AM
Good switch for Stepped attentuater, Good cheap RCA jacks pjpoes Parts 20 10th March 2005 08:47 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
