Lowest V at which damper diode tubes work
Does anyone have any info about what is the lowest V at which these tubes start conducting?
Do we have to push them hard or just get past their forward voltage drop?
I am mostly interested in 6CT3 and 6D22S families, and want to try them on low voltage and low current line level circuits (10 - 35V at a few 10ths of mA).
PS
Please do not waste your energy suggesting a solid state bridge or diodes. It is what I am currently using.
I want to try tubes for various reasons, most of which are rather controversial :)
I did not find a datasheet that has any sort of curves.
Vacuum diodes usually start conducting at 0 forward so there is no concern about minimum voltage.
Mercury vapor and xenon like the 3b28 have a starting voltage.
The 6CT3 and 6D22S should be OK at any voltage within reason.
