Resistor ratings for a small tube circuit? - diyAudio
Old Yesterday, 04:42 PM   #1
markusA is offline markusA  Sweden
markusA's Avatar
Default Resistor ratings for a small tube circuit?
I'm somewhat embarrassed to be asking some truly trivial things here but please bear with me.
It'll be a tube splitter.
The circuit is nice and tidy but I need some help in picking the right resistors for the job. I have a 10kΩ cathode resistor with a idle current of 10mA. Maximum current Swing will naturally be 0-20mA.
What kind of resistor is suitable and what power rating should I aim for?
The power supply will be very basic with a CRC filter. So, the power supply will be driving the circuit mentioned above. (10mA idle current draw.) The "R" will be 1kΩ , what power rating should I use and what kind of resistor would be suitable?
I was originally thinking of using 220μF caps but I might consider going bigger if the cost increase isn't too steep. Maybe 470μF?
It doesn't have to be special or fancy I just want functional and avoid letting the magic smoke out.
Current build to be found in my blog. Not so current anymore, everything is put on hold until march.
Old Yesterday, 05:14 PM   #2
DF96 is offline DF96  England
You can calculate (or estimate) the power dissipation in each resistor. Then pick a bigger one, bearing in mind that the resistors will be under a hot chassis.
However, in many cases the real issue is voltage rating. Resistors may only be dissipating a few 100's of mW so 1/2W might look OK, but you may need to use 1W to get enough voltage rating. Read resistor datasheets.
10k at 10mA is 100V which means 1W, so this one needs to be 2W or greater.
Old Yesterday, 05:18 PM   #3
markusA's Avatar
Does it matter what kind of resistor I use? It seems wirewounds are the most common for higher than W.
Old Today, 11:08 AM   #4
Wirewounds are expensive. You can get 1W film resistors. In some cases 0.6W film will be fine too.
Old Today, 11:22 AM   #5
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
It also depends in the resistor position. If it is mounted vertically, say the axis of it vertically, the disipation of the heat is better and the capacity to ground, lower; than if it is horizontaly positioned.
If anything can go wrong, it will.
If anything just cannot go wrong, it will anyway.
Old Today, 12:39 PM   #6
markusA's Avatar
Since I'll be doing the PCB myself I can choose the orientation freely.
I'm tempted to opt for 1W and 0.6W film resistors and just keep my fingers crossed. Maybe standing the borderline resistors up would be the final touch that keep them from letting the smoke out?
PCB is probably redundant but I like to keep things neat if possible. Would mounting the PCB upside down mess with heat dissipation? It's a handy way of having the tube peaking through the top of the case...
Old Today, 12:58 PM   #7
Try to avoid 'borderline' resistors. Don't cross your fingers; instead, read datasheets and use a calculator.
Poking the valves out of the top of the case will help keep the rest of the circuit cool, but it can be dangerous for the valves - especially if there are children in the house - and dangerous for the children too.
Resistor watt ratings and substitutions HiFiHarv Parts 3 31st August 2012 03:24 PM
What resistor power ratings should be used in guitar effects pedals? Test Electrix Instruments and Amps 2 4th February 2010 03:22 AM
Exceeding Impedance Ratings (of a small amp) CCmachine Solid State 1 24th July 2009 08:01 PM
Newbie question regarding fuse's and resistor ratings neil_kaye Parts 7 2nd July 2006 08:29 PM
Resistor wattage ratings whitey_woltrap Multi-Way 0 22nd March 2002 08:20 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
