Questions about tetrodes for specialists - diyAudio
Old 1st December 2016, 08:28 PM   #1
aldovan is offline aldovan  Brazil
Default Questions about tetrodes for specialists
Friends
I found a type 36 tetrode and built the above circuit to test it as a preamplifier. However, I observed that from 20Hz to 15KHz the circuit provides 35Vpp at the output, but this voltage goes down to 27Vpp at 20KHz.
What can cause this loss of gain? The capacitances on the tube look ok.
Aldovan
Old 1st December 2016, 08:31 PM   #2
JonSnell Electronic's Avatar
Probably the design and characteristics of the valve.
A pentode, by the way, has 5 electrodes.
Support for Fender, Marshall and all Valve Equipment including Audio Innovations, Quad and Leak. www.jonsnell.co.uk
Old 1st December 2016, 08:44 PM   #3
Matt BH is offline Matt BH  United Kingdom
Take a good look at how you are feeding G2.
Cheers
Matt
Old 1st December 2016, 08:59 PM   #4
hpeter is offline hpeter  Slovakia
hpeter's Avatar
oh no, the kinky one
BLOG. XMOS_U8/PCM5102A > LL1544A > 6H1Pi+Ķfoll > 2A3_SOV/JJ > LL1660 > STAX SR207 STAX SR007 # LL2748 > 394A > LCLC 4H/100Ķ
Old 1st December 2016, 09:10 PM   #5
Cheers
Matt
Matt
What is the problem on g2 ?
Aldovan
Old 1st December 2016, 10:10 PM   #6
artosalo's Avatar
Have you verified that your test setup has not such capacitance that it could load the signal at 20 kHz ?
How did you measure the output voltage ?
What is the impedance of that test device ?
Old 1st December 2016, 10:16 PM   #7
I use a Šudio generator with 800 ohms impedance and a oscilloscope for mesure the wave.
Old 1st December 2016, 10:39 PM   #8
SpreadSpectrum's Avatar
10x probe?
My Blog: http://tubeswithatwist.blogspot.com/
Old 2nd December 2016, 01:04 AM   #9
kevinkr's Avatar
What Artosalo and Spreadspectrum said.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 2nd December 2016, 01:06 AM   #10
jackinnj's Avatar
Matt
Aldovan
You only have half of a voltage divider
Why, silly hare, are you fleeing from the fierce jaws of the lion now grown tame?
Focal Specialists I need your help Audiom 7V313 MIDRANGE domtweaker Multi-Way 6 5th July 2011 03:28 PM
Semicon Specialists here? weissi Solid State 9 6th May 2008 10:18 PM
Question to the electromechanical specialists crazyhub Multi-Way 18 3rd June 2007 02:28 PM
RCA 7094 tetrodes... nickds1 Tubes / Valves 2 15th May 2006 07:28 AM
Question for TL Specialists SilverJS Multi-Way 2 29th November 2004 11:14 PM
Copyright ©1999-2017 diyAudio
