| diyAudio Sponsor | ||
this is my PSU schematic (for tube buffer), and i want to include choke, but I dont know what kind of value it should be....
if I"m understand corectly, choke give caps more capacitance (theoreticly)....Am I right? thanks
too much is just enough |
#2 |
2mH is the rule of thumb.
Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#3 | |
Somewhere in the region 5H-10H is usual for filter chokes for valve circuits. It depends on the current draw really. Get the PSU designer program from www.duncanamps.com and you can simulate the power supply. Its a must for power supply design. The circuit seems a little odd to me. I'd have put the larger caps after the choke so that the power transformer is less stressed. Also IMO bypassing the later caps does more good than the earlier ones. I'd swap the positions of all the capacitors. |
#4 |
For a FET amp it sure is 2mH, I didnt know its different for tubes.
Magura
#5 | |
diyAudio Moderator Emeritus
A capacitor has a high resistance to low frequencies and passes the high frequencies easier. So the choke tries to hold back the high frequencies while the capacitor passes the frequencies. Because the capacitor is from the b+ to earth it "shunts" high freqs like noise and ripple to earth. Dibbi is right that generally the choke is 5-10 H For solid state amps the figure is so much smaller because there is a LOT more current being pulled from the PSU so 2mH usually used since making a choke 5H that can pass 5A would be pretty HUGE! Cheers, Bas |
#6 |
First of all, reduce your first caps to like 20uF and pull one of the two 2nd stage caps. Choke should be between 5 and 50H, doesn't really matter. Anything over 5H will provide more than ample filtering but much more than 50H will have a lot of resistance. I'm assuming you're not drawing the 400mA your capacitor values suggest.
And guys, Magura is perfectly correct, that is, if he were filtering 3kHz. Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#7 |
Obviously Nelson Pass thinks its worth filtering 3kHz, cause he uses a 2mH inductor in the power supply of the SOZ.....or it could be the case that 2mH does the trick pretty much??
Ive used 2mH for a ZEN V1 with great succes. Magura
#8 | |
diyAudio Senior Member
Not for a tube based amp though, the voltage/current relations are diametrically opposed to what you do with semis. Cheers,
Frank |
#9 |
Yep, 2mH would also be quite sufficient if the caps above were several tens of mF. But even at 160V those would be enormous and last the preamp through the night on a single charge!
Tim
| Choke rating for choke input duty | cbutterworth | Tubes / Valves | 14 | 9th November 2007 04:43 PM |
| Swinging choke vs std. choke in PS | Curly Woods | Tubes / Valves | 2 | 5th March 2007 08:30 PM |
| Swinging Choke or Smoothing Choke | danFrank | Tubes / Valves | 4 | 11th February 2007 11:05 AM |
| L as a choke. | bogdan_borko | Solid State | 9 | 9th September 2006 09:48 PM |
| SS PSU without choke | Mikael Abdellah | Tubes / Valves | 29 | 15th January 2003 04:34 PM |
| Page generated in 0.10263 seconds (76.27% PHP - 23.73% MySQL) with 11 queries |
