The MDF amp chassis discusion reminds me...
Old 7th March 2004, 08:12 PM   #1
tom1356 is offline tom1356  United States
Default The MDF amp chassis discusion reminds me...
I want to rebuild my 300b mono block amps into new chassis. I would be building them from hard woods with a solid silver top plate. The twist is I want to make most of the base 5-6” thick and solid wood. Then I want to bore out recesses in it and pot the caps (with their cases removed), resistors, chokes, trannys, even the hook up wires- in it. Nothing on these amps gets warm besides the tubes and a 25w 1k resistor. What am I overlooking? What (besides the tubes and that resistor) can’t I do this with? I know this will make it very unfriendly to modify and repair but I can deal with that. Any ideas? Cautions? Warnings?
Thanks for any help!
My "cult-like" following is accepting applications.
Old 7th March 2004, 08:31 PM   #2
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
The MDF amp chassis discusion reminds me... Send a message via AIM to Peter Daniel
If you are doing it for the first time, you can't really predict the results. It may seem like a proper and sound approach, but when you put everything together, the sound may be not to your likening. Especially if you use expensive components and then you'll pot them. It will be very hard to take them out if you decide that this is not what you are after (soundwise).
I would suggest building two circuits, with less expensive parts, and do with one what you intend here, and then compare them sonically. IME damping chassis and components too much is not always suitable.
Old 7th March 2004, 08:38 PM   #3
Peter-
Very good point. Someone has to be first at everything. I would think it wouldnt be that hard to reverse the project if I used a high temp wax to pot it all and found it to be poor sounding.
Thanks for the input.
The MDF amp chassis discusion reminds me...Hide this!Advertise here!
DIY cd chassis SA-12 Parts 2 24th March 2009 10:54 PM
5E3 chassis Colinsky Everything Else 0 23rd July 2008 11:10 AM
What d'you put in the PSU chassis, and what in the circuit chassis? andyjevans Tubes / Valves 5 15th December 2007 12:41 AM
How to star ground to Chassis without a Chassis?? Minion Chip Amps 10 5th November 2006 05:28 PM
Where to get chassis or chassis parts in Vancouver? Prune Parts 1 7th July 2004 06:37 PM
Copyright ©1999-2017 diyAudio
