Plasma/ionic
Plasma/ionic
Old 6th September 2004, 07:37 AM   #21
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Woot.
I'd recommend a pentode... nice constant-current characteristic... add some degenerative (cathode) feedback of some sort to linearize the distortions.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 6th September 2004, 12:38 PM   #22
On Hiatus
SY's Avatar
Plasma/ionic
Last week, I visited a company that specializes in creating free-air and air/argon plasmas in large volume spaces (like one or two cubic meters). The 125kV transformers were very impressive. I immediately started thinking about how to modulate them via their primaries...
Plasma woofers, the next step.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 6th September 2004, 08:05 PM   #23
Prune is offline Prune  Canada
Account Disabled
You need a sheet of plasma thinner than the smallest wavelength to be reproduced. I don't think you can manage that with such a setup. An array of discharges may be a better idea.
Old 11th November 2004, 03:11 AM   #24
Account Disabled
Power supply is done, and here are the output devices.
Since I'm using one output tube per channel, some current sharing resistors will have to be used to split the power evenly between all plasma cathodes.
Old 11th November 2004, 06:10 AM   #25
DigitalJunkie is offline DigitalJunkie  United States
Send a message via AIM to DigitalJunkie
I remember an article in either Electronics Now/Radio Electronics/Popular Electronics (whichever name it had that week..)
About building a plasma tweeter.
I forget the circuit details,but they used a small alcohol lamp...
I might have that issue around somewhere...I'll have to look..
Old 25th November 2004, 01:34 PM   #26
Account Disabled
Legal question: Do I need to ask permission for using a patented design even if I build it for my own experimentation and do not use it to make money? I'm wondering if I need to contact Dr Hill to ask if I can use his design from the plasma patent. I'm just worried that he might say no, in which case I'll be in a worse position than if I hadn't asked.
Old 25th November 2004, 01:42 PM   #27
markp is offline markp  United States
If it is for private non-comercial use you are ok.
If it sounds good... it is good!
Old 25th November 2004, 01:43 PM   #28
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
I don't think so...
Frank
Old 25th November 2004, 05:11 PM   #29
bear is offline bear
expert in tautology
bear's Avatar
Plasma/ionic
Coupla points:
DC discharges of the HV type that are also at high currents are DANGEROUS. You can get dead quickly with HV at relatively modest currents. Like <100ma.
NATURAL GAS!! SPECTACULARLY BAD IDEA!!
People get really burnt and dead when that natural gas goes BOOM! Bad idea.
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 25th November 2004, 10:55 PM   #30
Sch3mat1c's Avatar
Heh.
Propane is fun, you could leave an unlit torch blowing in the basement all night amidst flaming water heaters and heating furnaces and still get nothing. Why? Because, it's the correct mixture *coming out the torch*. It just dissipates further in the air.
Not that I would recommend anyone actually try that... I don't know how strong the diffusion is (propane is much heavier so will settle, unlike methane which will float harmlessly out, unless there is an utter mess of it).
Tim
Plasma/ionicHide this!Advertise here!
DIY Ionic air cleaner. tade Everything Else 16 28th September 2010 08:39 PM
plasma on e-bay inertial Planars & Exotics 11 17th January 2009 02:57 PM
Plasma/ion tweeters Prune Tubes / Valves 0 16th June 2004 04:31 PM
