We're often concerned about RF oscillation within the amplifier more than external RFI sources. My personal approach to this problem is to own a scope with 300~500MHz bandwidth so spurious oscillations cannot hide from me and I can avoid grid stopper overkill. Be aware that touching a probe to some circuits can stop an oscillation, so it's wise to use the probe more like an antenna when troubleshooting. I have a 3GHz RF spectrum analyzer as well, but I've never confirmed a spurious oscillation in an audio amplifier in the GHz range.
IF you have internal oscillation problems firstyou need to improve separation, shielding and grounding rather than applying a band aid solution.
At least in my experience, the main utility of grid stoppers resides in stopping external RF interference, mainly Radio stations.
The primary purpose of a grid stopper is to stop parasitic RF oscillation. For this it is not a "band aid" but the correct tool for the job; it adds positive resistance to overcome the negative resistance seen at a valve port. Only when unusually high values are needed can it be seen as a substitute for good layout. Note that grid stoppers may increase the risk of feedback loop instability, by adding phase shift.
A secondary purpose is to filter out incoming RF, but a proper filter may be better.
I have experienced grid (g1) stoppers necessary only with some high gm pentodes.
Never with medium mu triodes.
Sometimes a cap from grid to the ground is better than a stopper.
There is no feedback in the mixer so phase shift isn't a problem.
I have added a 10k to each grid input right at the valve.
I have included the layout below minus the copper pours.
The ground line is in violet to highlight it.
same Audio Note and others brands have 220pf grid to ground
Never???
For my experience, the grid-stoppers resistors haven a other propietie: dont block the prevoius cap . The sound is ever quick !!!
I use them in all my tubes for this reason.
Cheers
- Tubes / Valves
- How many grid stoppers do I need ?
