Large caps in PSU without choke?
Old 4th March 2004, 03:13 PM   #1
G is offline G  United States
G's Avatar
Default Large caps in PSU without choke?
Hi All,
I'm getting ready to rebuild my SE EL84 amp onto a nicer chassis and I have a question. I have a pair of dual section Elna Cerafine 220uF/450volt caps that I would like to use. Since I'm not using a choke in the PSU I should be able to use them shouldn't I? I have been using 32uF/500 volt dual section caps. Thanks.
Gavin
Old 4th March 2004, 03:47 PM   #2
Mikael Abdellah is offline Mikael Abdellah  Sweden
Tube rectifier? I have 2x2200uF 400VDC in my amp with a SS-rectifier. Works great.
Old 4th March 2004, 04:58 PM   #3
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 4th March 2004, 05:46 PM   #4
Originally posted by Sch3mat1c
Have you ever heard my amp?
Old 4th March 2004, 07:54 PM   #5
Sch3mat1c's Avatar
No, but I can hear the death screams of your power transformer's winding (unless it's hideously overrated) from here.
Tim
Old 4th March 2004, 07:54 PM   #6
G's Avatar
No the rectifier is a GZ34.
Gavin
Old 4th March 2004, 09:46 PM   #7
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
A GZ34 is only rated for maximum reservoir capacitance of 60uF. If you put 220uF directly on its output, the ripple current will quickly kill it. However, there's nothing to stop you using a 68uF as a reservoir (modern capacitors are far closer tolerance, so the slight, but controlled increase will be OK). You could then follow that with RC smoothing using your 220uF capacitors.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 4th March 2004, 09:58 PM   #8
G's Avatar
Thanks!!
Gavin
Old 4th March 2004, 10:12 PM   #9
richwalters is offline richwalters
richwalters's Avatar
Hi there.........really there's no need for so much cap/Joules...that sort of value sits in power drives.
rich
Old 4th March 2004, 10:59 PM   #10
316a is offline 316a  England
316a's Avatar
Default Capacitors
Hello ,
If you're retaining the GZ34 why not upgrade to capacitors to motor runs ? 30uF 440V AC are easily obtainable and cheap . An improvement over electrolytics , as long as your chassis is big enough to house them...
316a
Large caps in PSU without choke?Hide this!Advertise here!
Large caps Stuart Easson Swap Meet 26 25th March 2009 03:57 AM
Paralleling small value caps with large value PS caps xyrium Power Supplies 16 14th October 2005 04:06 PM
Large PSU caps for sale. jleaman Swap Meet 3 23rd October 2004 04:28 AM
Adding large caps? Rino odorico Everything Else 6 13th September 2002 10:16 PM
Copyright ©1999-2017 diyAudio
