| diyAudio Sponsor | ||
If I change my amp from diode to tube how much of a voltage drop can I expect? What would be a good tube to use(I would like one to fit an octal base, Have an extra on the chasis)?
Thanks |
#2 |
Voltage drop depends on the tube used. You could use an 83 mercury vapour tube since those have pretty much no drop, but I believe that it is a 4 pin tube. A 5U4 would have about a 15V drop, its also a common tube used and somewhat beefy; a close relative would be a 5AU4 which is just way beefier, its rarely used in mainstream amps so it would be a good choice, its also octal. A schem of the amp would help, also the current and voltages.
#3 |
normal tube rects - depends on the amount of current drawn.
merc'd rects.. (83, etc) is ~15v through the whole range of current. 5U4 @ ~200mA is something like a 45v drop. |
#4 |
Mind that I've never seen a single merc toob rated for more than 5uF cap input. In other words, they require a choke input filter. You'll drop about 1.3 to 1.5 times the voltage as compared to a SS rectifier (with cap input) in doing so.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#5 |
Thanks, gives me a place to start. I will be going with a choke setup I think. Any thoughts on the 5ar4?
#6 | |
316a |
#7 |
If you need some PY 500A or PY88 valves, I have a pile of the things, all NOS and nout to do with them!!
Make us an offer!!
Das Beste Oder Nichts |
#8 |
Hi all,
I was thinking of starting a thread on some of the better damper diodes to use, but since it's been brought up here, I might as well piggy-back my question on it now: Given the current price of good sounding GZ34's I guess it would convienient if they didn't use top-caps; but ultimately, I'm not really fussed about that. I'll do what it takes to get good quality. (Addendum: At the moment, my anticipated application for them is for a balanced preamp curcuit.)
check out my avitar and go easy on me ok? :-) |
#9 |
good sounding diodes eh?
ah.. i'll be nice this time. |
#10 | |
I am aware that not everyone thinks that individual component types (let alone brand...) have sonic signiatures of their own. So rather than re-start a controversy that I'm sure has been had on these forums already in many guises; my 'plea' for assistance goes out to who have already had a play around with some of these already, and might be able to offer some reccomendations. I've only used GZ34's in the past myself (and the odd GZ37), and unfortunately I ain't rich enough to afford buying handfuls of each type of available damper diode to try myself, so I thought I'd ask those who might have gone through this already. cheers again.
| 4v for rectifier tube | camotecue | Tubes / Valves | 10 | 20th May 2008 09:20 PM |
| Tube rectifier help | Cobra2 | Tubes / Valves | 12 | 3rd March 2007 01:58 PM |
| Z2b tube rectifier | bee696 | Tubes / Valves | 3 | 4th November 2006 02:45 PM |
| Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? | zxx123 | Tubes / Valves | 4 | 21st February 2005 04:02 AM |
| Tube rectifier for VDIGC tube psu | ebijma | Chip Amps | 2 | 11th March 2004 04:02 PM |
| Page generated in 0.11248 seconds (76.85% PHP - 23.15% MySQL) with 11 queries |
