resistors, capacitors, etc. NEED MORE INFO! - diyAudio
Old 4th March 2004, 01:42 AM   #1
Send a message via AIM to sjay8179
Unhappy resistors, capacitors, etc. NEED MORE INFO!
i need help with schematics.. the guy at radio shack says there's not enough info about the wattage of resistors and other stuff that he needs so he can get the parts i need. its really annoyin cause theres no schematic online that has that info... is there a way to find the other information on the schematic, but it just aint obvious?
Old 4th March 2004, 12:41 PM   #2
diyAudio Senior Member
fdegrove's Avatar
Maybe if you could post the schematic we could figure it out?
Frank
Old 4th March 2004, 09:29 PM   #3
well heres a part of it:
Old 5th March 2004, 09:40 AM   #4
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
Try a link Or just describe the circuit in words...
Old 5th March 2004, 12:05 PM   #5
SY's Avatar
That's what you get for shopping at Radio Shack.
Use 1W resistors for the plates, 1/2 watt for cathodes, grid and EQ resistors can be anything small (1/4 watt will be fine). Anything else, actually take the trouble to use Ohm's Law to estimate the power dissipated, then double that for a safety margin. It's OK to use 1W where 1/4 watt is needed but not vice versa!
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 6th March 2004, 01:55 AM   #6
well i think i got it this time
the schematic
Old 6th March 2004, 01:04 PM   #7
thanks SY for the info
WTB - capacitors and resistors jeffshort2000 Swap Meet 4 9th January 2007 12:46 AM
[Request] Resistors and Capacitors MC Swap Meet 1 6th June 2004 03:55 AM
resistors and capacitors in leach amp Wagener Solid State 3 30th April 2004 10:42 PM
Resistors and Capacitors DVDHack Tubes / Valves 9 29th January 2004 07:49 AM
Signal Capacitors/Resistors StefanJ83 Parts 2 23rd October 2001 06:47 PM
Copyright 1999-2017 diyAudio
