Using Telefunken "Tank" transfomers for a single ended el84 amp? Using Telefunken "Tank" transfomers for a single ended el84 amp? - Page 2 - diyAudio
Old 8th March 2004, 10:55 PM   #11
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Quote from Glassware:
The Voltage Doubler power supply configuration allows the creation of a power supply whose output voltage far exceeds the peak transformer secondary voltage. Two diodes, two capacitor--that's all there is to it. Only one half of the voltage cycle is used in each leg of this circuit, that is, one diode conducts, then the other--each builds up a voltage in its associated capacitor, which are in turn stacked one above the other, thus, doubling the voltage.
So what you need is 2 * 1N4007s , a cap of say 470F/250VDC that goes inbetween the tiepoint of the diodes and finally another cap of say 47F/400VDC to build your basic supply.
It will yield a voltage much higher than you require for the EL84s and the input tubes but at least you can now smooth further by either RC filtering or better still choke filters.
Keep in mind that the total current available is only half of what the xformer could have delivered without the voltage doubler.
Frank
Old 8th March 2004, 11:12 PM   #12
ark is offline ark  United States
Thanks. That's very interesting.
I have a filter choke someplace:
(CHICAGO TF1A04YY Filter Choke. 5HY 400ma. 60 ohm DCR)
Too big?
That will knock the voltage down a bit right?
I'm wondering now: where do I rectify to DC then?
Before or after the Diode doubler?
I still really want to use a tube rectifier if only for aesthetic reasons.
Old 8th March 2004, 11:31 PM   #13
fdegrove's Avatar
The 5H will be fine, bigger is even better but since this is what you have...
The 60 Ohm DCR won't bring the voltage down enough, you'll only need about 250VDC and you're looking at about 400VDC coming from the doubler.
Actually if you'd had about 10VAC more from the xformer a bridge rectifier would have worked fine....
There are tricks to add another xformer to the secondary but I'm no big fan of those stunts.
Reread the quote I pasted in the previous post; it's done...finito, simple as that.
Stick a candle on top of it...??
Seriously, do whatever you fancy but you can't have your cake and eat it too...so it's either the diodes as doubler or a totally different project altogether.
A preamp iso an amp for example, even so B+ will inevitably on the low side of good.
Frank
Old 8th March 2004, 11:32 PM   #14
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
For EL84s (better yet SV83s), i'd just bite the bullet and put a diode bridge on the 177V... you should get somewhere around 240 V -- maybe a bit low (you won't get quite as much power), but still fine. Use the choke in a CLC to get as little voltage drop as possible... the 6DJ8 will be more than happy with what you get.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Using Telefunken "Tank" transfomers for a single ended el84 amp?Hide this!Advertise here!
Single-ended-series amp with a "1 winding" transformer tubee Tubes / Valves 29 8th February 2015 06:33 PM
"Mighty Mite" Single Ended Amplifier wrenchone Tubes / Valves 13 20th October 2008 04:57 AM
glass audio 1995 "Single Ended Glory" habsrock93 Tubes / Valves 3 22nd June 2008 02:10 AM
FS: Audio Note 20H 50mA choke; Black Gate Wk "power tank"; Jensen PI0 Joseph0 Swap Meet 0 8th April 2006 01:08 PM
FS: Homebuilt "Aikido" 2A3 single ended triode amp jim_vt Swap Meet 11 21st January 2006 03:38 PM
Copyright ©1999-2017 diyAudio
