| diyAudio Sponsor | ||
can someone show me, how to build mu CF with ECC88, power supply +/- 50 V or 100V, with gain 3, input res on my amp is 4,7Kohm (3,5V ,700uA)...
thanks
too much is just enough |
#2 |
Hi trancy
A CF alone has no gain ( gain <1). It has to be preceded (or followed) by a gain stage. Federico |
#3 | |
I was trying to make a schematic in micro-cap, but probably Im too stupid.....
#4 |
Hi trancy
Last year I was in Bled for my white week holidays Beautiful place. I'll send you a pic for a 6dj8 common cathode followed by a CF. But since a gain of 3 is very low I have to attenuate the input or the output. Federico |
#5 |
A mu stage has a CCS-loaded triode (although it should work with pentodes just as well) with CF output. Think about it!
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#6 |
Trancy,
Attached is a cathode follower followed by a common cathode stage. I was told that tubes such as 6DJ8, 6922, ECC88, 6N1P can be used for such a configuration. Federico, Would it be possible for you to provide values for the resistors using 6N1P and ECC88 tubes? I have a couple of 6N1P sitting here waiting to be used. Thanks! JojoD |
#7 | |
Iam waiting for your sch. .....thanks a lot...
#8 |
Hi trancy
Sorry for the delay, but yesterday I had not success in connecting to the forum. here is the pic ciao Federico |
#9 |
JojoD
what is the input resistance of the amplifier? ( I am supposing that this is a preamplifer which will drive an amplifier) ciao Federico |
#10 |
thanks a lot federico, I will report how it works soon...I hope without smoking signals....
| Question about direct coupling a anode follower into a cathode follower. | G | Tubes / Valves | 45 | 29th July 2004 07:47 PM |
| cathode follower | ackcheng | Tubes / Valves | 2 | 6th July 2004 04:12 PM |
| Cathode Follower? Yay or nay? | SHiFTY | Tubes / Valves | 25 | 16th March 2004 07:38 AM |
| cathode follower | olvrkrg | Tubes / Valves | 3 | 21st February 2004 10:49 PM |
| Page generated in 0.25019 seconds (34.32% PHP - 65.68% MySQL) with 11 queries |
