cathode follower with gain
Old 6th March 2004, 01:54 AM   #21
JojoD818 is offline JojoD818  Philippines
JojoD818's Avatar
Originally posted by fscarpa58
2W for 20k e 30k res
for the other ( 200, 1meg, 270k) also 0.2 W.
I like the topology very much but, in this case,
and with 6N1P, we need 300 V to have it working properly.
Owing to the constrain due to the rigid connection
between plate of 1th tube and grid of the 2nd, the working
point is not very good, that is high distortion
( 0.4% at 5Vrms out) and not very great max swing.
However it works and maybe you will like its
sound.
If you don't need gain the CF is advisable.
Federico
Thanks Federico! Will give you updates soon.
Old 6th March 2004, 02:52 AM   #22
AKSA is offline AKSA  Australia
Federico,
I agree with your comment about the poor operating point of the direct coupled CF. It does not sound so good.
However, the configuration has a huge advantage.
If the output is taken from the plate of the first tube, not from the cathode of the second, and if the plate resistor is made equal to the cathode resistor, then we have perfect current balance as long as the plate is held at half B+.
This means that the current draw of the two triodes will add to a constant; viz, perfect current balance. This makes power supply design very easy, and improves the bass performance a great deal because there is no voltage sag on the B+.
In 1999, John Broskie of Tubecad.com came up with this approach; I think it is very clever.
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 6th March 2004, 02:37 PM   #23
trancy is offline trancy  Slovenia
trancy's Avatar
However
this has about 25 db of gain.
I really do not like it.
federico, are those (in post #16) values for ecc88, or some other tube? if its not, could you recalculate for me....
i'll be grateful
too much is just enough
Old 8th March 2004, 08:44 AM   #24
fscarpa58 is offline fscarpa58  Italy
Hi trancy
You have to decide.
post #16 is addressed to JojoD.
The cir has high gain, 150 V B+ supply,
it is tuned for 20k load, and uses 6n1p.
I post a message for you a few days ago.
It was a 3db gain with 100V B+, uses 6DJ8/Ecc88
and was tuned for 4.7k load.
let me know.
Federico
Old 8th March 2004, 08:48 AM   #25
Hi Hugh
I agree with you, and I also consider
Broskie idea a very good one.
Federico
Old 8th March 2004, 08:59 AM   #26
trancy's Avatar
Hi trancy
You have to decide.
let me know.
Federico
sorry for inconvenience federico,
I"ll try to make CF on 100V B+ with ECC88 from your schematic, and also I want to try on 150V B+ with same sch.(if I"m correct, higher B+ is better for sound quality)...
is there any simple formula to recalculate values, or its nessesary to have some tube related sw?
I really dont want to bother you federico, but...you know....I dont know anything about tubes...this is my first one....practicly I am a tube virgin....ohhhhh yeaaahhh....
Old 8th March 2004, 09:25 AM   #27
Trancy
I am happy to help you.
But I need clear data to work on.
1) type of circuit
2) tube
3) gain
4) B+
5) load
If you only want that I recalculate values for circuit of
post #8, here is the pic.
Federico
Old 8th March 2004, 10:00 AM   #28
trancy's Avatar
great...thanks federico.....
thats all I want this moment....i will report you, how its work....
Old 8th March 2004, 10:49 AM   #29
trancy's Avatar
federico,
those values of resistors, is enough for 14K resistor to be 1/4W, and for 200E 1W ?
Is it O.K., if I use 14,7K instead 14 and for 180 ohms instead 200 ohm....?
its hard to find exact values ( I have 14,7K and 180 E)...
thanks
ciao
Old 9th March 2004, 11:18 AM   #30
Yes , it's o.k.
No, actual static dissipation of the 14.7k res. is a bit less
of 0.5 W so I advice you to use at least 2W to 4W res.
the 200R res dissipates less of 10 mW so you can safely
use 0.1W res
Federico
cathode follower with gainHide this!Advertise here!
Question about direct coupling a anode follower into a cathode follower. G Tubes / Valves 45 29th July 2004 06:47 PM
cathode follower ackcheng Tubes / Valves 2 6th July 2004 03:12 PM
Cathode Follower? Yay or nay? SHiFTY Tubes / Valves 25 16th March 2004 06:38 AM
cathode follower olvrkrg Tubes / Valves 3 21st February 2004 09:49 PM
