Lafayette LA-240. Schematic please.
I cannot find the original schematic either. But looking at some pictures on the web it looks very similar to a LA-224. Probably with higher plate voltage to achieve the higher output power: I can clearly see the EL84 shared cathode resistor of 200 Ohm in stead of 130 in the LA-224. As the Lafayette schematics are straight forward I think you cannot go wrong to take the schematics of the LA-224 and LA-235 to start with.
That should be it:
