PSUD II question - diyAudio
Old 3rd July 2016, 03:46 PM   #1
mr2racer's Avatar
Default PSUD II question
I have an Antek power transformer that has two possible end taps. One has an off load voltage of 326 the other 345. There is no center tap. According to PSUD;
For full wave rectifiers, use the voltage for one side only. For example, if the transformer off load voltage is 350-0-350V (700V end to end), the correct value to enter is 350.
I want to use a 6X4 full wave rectifier. So do I enter 345 or 172.5 when entering the off load voltage?
Artificial intelligence is no match for natural stupidity- Red Green
Old 3rd July 2016, 04:11 PM   #2
jazbo8's Avatar
You need to select Bridge rectifier.
Old 3rd July 2016, 04:23 PM   #3
Ketje is online now Ketje  Belgium
Ketje's Avatar
If there is no centre tap, where do you get the 172.5V ?
Mona
Old 3rd July 2016, 04:27 PM   #4
mr2racer's Avatar
That's my question. Without the center tap do you still use half the voltage for a full wave rectifier?
Old 3rd July 2016, 04:38 PM   #5
Sodacose's Avatar
The full wave option in PSUDII assumes a center tap. You want to use the bridge rectifier version and use the whole secondary value (no center tap means no dividing by 2).
WTF Amps || /r/diytubes/
Old 3rd July 2016, 04:54 PM   #6
mr2racer's Avatar
Thanks guys. I should have noticed the schematic for a full wave tube rectifier includes a center tap. I could do a bridge but I would need another 6x4
Old 3rd July 2016, 05:40 PM   #7
Sodacose's Avatar
I've never tried it, but there is such thing as a hybrid bridge. See this page from Merlin:
The Valve Wizard
I don't think PSUDII can model it though.
Old 3rd July 2016, 05:48 PM   #8
The Valve Wizard
I've heard one (#26 pre amp post #3648) and it has inspired me to build a type 26 pre. Ironically, full wave without the hybrid bridge.
Old 3rd July 2016, 06:11 PM   #9
DF96 is offline DF96  England
No, you would need two more 6X4 to make a bridge. This is because dual rectifers almost always have a common cathode, but to make a bridge from two vacuum rectifiers you would need one of them to have a common anode and separate cathodes.
Old 4th July 2016, 12:00 AM   #10
Sheldon is offline Sheldon  United States
The Valve Wizard
You can approximate it. Model a tube bridge, then model a ss diode bridge. Split the differences. It comes out pretty close. Or you can model a half wave tube rectifier, using half the current, to get an approximation. Losses due to a ss diode can be ignored, as they are small.
Sheldon
Is PSUD II trust-worthy or not? matej8888 Power Supplies 24 14th April 2012 07:12 PM
SimpleSE PSUD II B+ squiffiness Tubelab 19 31st January 2012 03:15 AM
Need help with PSUD II model jrenkin Tubes / Valves 6 14th February 2010 01:12 AM
PSUD II soft start Richard Ellis Tubes / Valves 1 12th November 2009 03:41 AM
PSUD II help Bengali Tubes / Valves 10 15th September 2007 05:58 PM
Copyright 1999-2017 diyAudio
