diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Changing caps for preamp (http://www.diyaudio.com/forums/tubes-valves/29275-changing-caps-preamp.html)
ackcheng 1st March 2004 05:36 AM
On various forum, there are discussions on the sonic diffenence in the change of the 1uF caps to different brand like Jensan, MCaps etc.
I just wonder what would be the expected change in sonic characteristics by increasing or lowering the capacitance without changing the brand?
If i want to put capacitors from different brands in parallel, should I keep the total capacitor = 1uF?
analog_sa 1st March 2004 05:44 AM
As these are presumably coupling caps changing the value will have an effect on the high-pass formed by the cap and the input impedance of the next stage. Lowering may deprive you of some bass while increasing will allow lower frequencies through. Often increasing a cap above the value required produces more solid bass but at the expense of midrange quality. You just have to try and see how you like it. To my ears (sensible) variations in the values of coupling caps is not nearly as audible as using a different brand.
ackcheng 1st March 2004 02:54 PM
Resources saved on this page: MySQL 18.75%
