OTL, not OTL, & Matching VS Loading transformers
Let me be more specific (though you perfectly understand what I mean...):
when an output coupling capacitor is required (to block DC and this indeed depends on the output stage configuration) then the 3000 uF would be needed to ensure LF bandwidth.
It is obvious. The same way, like low inductance of a plate load transformer primary can be used as a HPF. :p
PS: it is an OT. Let's ask the moderator to move "OTL, not OTL, & Matching VS Loading transformers" into a separate thread?
Rewound impedance matching transformers for 10WPC, replaced the tube. Now it is 6Н6П, for twice faster slew rate. I did not expect to get more natural sound, but got it... Unbelievable!
