McIntosh MC275 problem. - diyAudio
Old 26th May 2016, 09:48 AM   #1
Archibaldy's Avatar
Default McIntosh MC275 problem.
Hi all,
Recently I bought a McIntosh MC275 valve amp.
My first question to the seller was "is it 120 volts or 240. (Australia has 240)
He assured me it was 240 volts. A week later I bought it.
It came with an Australian power cord (fits straight into our power points). (He could have just thrown that in easy enough)
On the chassis above the power input it states 110~120 volts. The print on the PT says the same. Also has a 4 amp fuse which suits USA voltage. (Aust 240v requires a 2 amp fuse).
Ok...
I have a stepdown transformer which I used but valves barely light up with next to no heat and sound is quite distorted with no power.
Could it be that it really is 240 volts. Not wanting to fry it I'm not going to try it, but it does seem like it's only getting half the required voltage
So, at this stage it is in limbo.
Andrew.
Old 26th May 2016, 10:26 AM   #2
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
How many primary halves does it have, and how are they connected?
The Devil is not so terrible as his math model is!
Old 26th May 2016, 10:54 AM   #3
JonSnell Electronic's Avatar
On the choke L1, there should be 450Volts DC. If it is 250 ish, the transformer is running at half supply. Original 275s were 117/125 selectable mains input. NOT 240V.
Support for Fender, Marshall and all Valve Equipment including Audio Innovations, Quad and Leak. www.jonsnell.co.uk
Old 26th May 2016, 11:01 AM   #4
Archibaldy's Avatar
I am not so knowledgeable about PT's but according to diagram on top of PT there seems to be 2 primary coils. (correct me if I'm wrong)
I don't know how they are connected. Not willing to open it up yet. It's heavy too - 67lbs.
Old 26th May 2016, 11:14 AM   #5
Archibaldy's Avatar
I'm waiting to hear from seller. Just heard and this is his message -
"US suppliers, delivery before changed to 240V.
safe to use.
Do not have any concerns"
Would this be normal practice ? I'd have thought that if it were so then they would have stamped or put a 240v info sticker on chassis.
Old 26th May 2016, 11:16 AM   #6
240 will be Black and white with Grey and violet connected together and insulated from chassis.
Old 26th May 2016, 11:20 AM   #7
When the diagram is correct you should connect GRY/BLK with VIO/WHT.
Then the Black and White taps should give some 234 VAC.
Also try to check the negative supply for the power tube grids.
We have an MC275 (maybe older type) which had a prehistoric rectifier; negative grid voltage was quite a bit lower than the specified -57 volt so the power tubes draw too much current.
Old 26th May 2016, 12:55 PM   #8
Archibaldy's Avatar
OK, Thanks for the responses.
As I wrote above, the seller assured me it has been changed to 240v before it left USA.
I took him at his word, plugged 'er in the wall socket and Woohoo.... Running like a humdinger Tubes lit up nicely.
It's getting late, I'll have to wait 'til tomorrow to let 'er rip through the Tannoys.
Andrew.
Old 26th May 2016, 01:08 PM   #9
Archibaldy's Avatar
I guess I was feeling bit panicky, after all it cost me an arm and half a leg.
CHEERS !!!
Mcintosh MC431 problem pmiller327 Car Audio 12 13th October 2013 11:08 PM
Mcintosh 427 Problem!! selmervi54 Car Audio 6 21st September 2012 11:18 AM
Convert a 110 volt Mcintosh Mc275 to 230volt matsj Tubes / Valves 20 24th October 2011 04:07 PM
PLS HELP! Strange Mcintosh MC431M problem stevexyz Solid State 3 18th April 2010 07:43 PM
mcintosh mc275 heavy mods!! richt Pass Labs 3 27th December 2001 12:08 AM
Copyright Đ1999-2017 diyAudio
