Schade Feedback In A Push Pull Differential Amplifier?
Old 16th September 2017, 09:54 AM   #261
Kay Pirinha is offline Kay Pirinha  Germany
Since a conventional cascode, consisting of two triodes, has an output impedance comparable to that of a pentode, I don't think that this MM arrangement is worse in here. Of course, plate (and screen) current is dominated by the bottom BJT.
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Old 16th September 2017, 12:01 PM   #262
nigel pearson is offline nigel pearson  United Kingdom
Originally Posted by smoking-amp View Post
I liked the pilot story about a Blackbird over the North Sea that had an engine failure. Pilot radio'd in to some Norwegian airport for permission to land and they OK'd that, even though nothing was on the radar. Then this big long black thing lands on the runway and the pilot gets out with a space suit on. They thought the Aliens had landed and called security, so the pilot asked for a beer to cool things down. Too bad they were so expensive to run and got put out to pasture. Something else up there now.
The house I hope to buy is a bit out of the way so uses heating oil. I have been learning how these boilers work ( 1880's style selenium [ Siemens ] cell to shut down the fuel if no flame detected ) . Seems the boiler in this house uses an oil that is very much like jet fuel. I think it is called 28 second oil. Older types use 35 second much like diesel. The Blackbird used a special safer fuel which allowed the plane to leak a little which was the way it had to work.
Interesting the the Music Man amp has caused debate. I can see an arguement to use as much shunt feedback as possible.The transistor could be a PNP NPN compound pair ( 2 x 2 ) of very high current gain and also low distortion in that element. That might be the way to get a low output impedance to drive the transformer. Over Schade it has some advantages. If the current gain is very high a nice linear driver could be used.
Old 16th September 2017, 01:01 PM   #263
At least in Germany, there aren't too big differences between heater oil, jet kerosene and diesel fuel. Actually, the main component of all three is kerosene.
Right. Getting the relationship between signal input and plate current as linear as possible will garant for low distortion, as in the load impedance only signal AC current counts.
Best regards!
Old 16th September 2017, 07:01 PM   #264
My big guess was the transistor side could be very low in distortion so allowing the valve to be itself ( or our choice of that ). This design in the link has a very full investigation into a feedback pair plus cascode albeit all transistor. One reason to look at this is the biasing could be exactly as a single transistor. Linearity will be better as will current gain over the Music Man. We could have a ECC83 doing a bit better than usual driving it as we could have a more ideal anode load ( perhaps ). The idea is super performance from very low cost parts. I have used a complimentary pair as the so called VAS in a transistor amp. It gave me no trouble and was a dream to drive.
MJR7-Mk5 Mosfet Power Amplifier Design Notes
Schade Feedback In A Push Pull Differential Amplifier?Hide this!Advertise here!
Local Feedback for Push Pull Pentode dsavitsk Tubes / Valves 22 4th December 2013 07:48 AM
Dual Simple SE's in Push Pull w Differential Input Anchan Tubelab 39 5th January 2011 04:10 PM
Differential push-pull design question Tyimo Tubes / Valves 4 15th January 2010 08:05 PM
A push-pull differential stage- why not? darkfenriz Solid State 53 23rd December 2007 02:00 PM
Global Feedback in Push Pull Amps gingertube Tubes / Valves 14 17th May 2005 05:22 PM
Copyright ©1999-2017 diyAudio
