Switch between tubes with relay
Old 12th May 2016, 02:16 PM   #1
emretelci is offline emretelci
emretelci's Avatar
Default Switch between tubes with relay
There is situation that I need help about switching tubes. The situation is I am making a guitar pedal (overdrive) with a tube... The original design has one tube, but I want to use three tubes and switch between them using relays. I know this sounds interesting but I am trying to figure out how I can do that...
Only one tube should be active and by using relays, I need to switch between tubes. My question is, where should I install the relays on this drawing.
Thanks...
PS: Pin 3 is connected to pin 4 on the schematics. And all the tubes are identical.
And here is the schematics:
Old 12th May 2016, 02:31 PM   #2
euro21 is online now euro21  Hungary
Do you mean, that you want to use 12AT7 tubes from different manufacturers?
Old 12th May 2016, 02:34 PM   #3
emretelci's Avatar
No, different but equivalent tubes like 5751, 12AT7 or 12AU7
Old 12th May 2016, 02:47 PM   #4
turk 182 is offline turk 182  Canada
are you thinking of switching all the connections from tube to tube?
heaters would need to see a constant supply otherwise warm up time will be a problem.
in looking at the schematic i'm not sure that plate voltages are adequate for a 12at7 nor does there seem to be any sort of voltage multiplier in the power supply.
interesting concept though.
Old 12th May 2016, 02:49 PM   #5
These are have equivalent PIN order, but not equivalent tubes.
Maximum anode current:
5751 has about 1mA, the other two capable about 10mA.
12AT7 and 12AU7 not equivalent, but mostly interchangeable (depending of the circuit).
Old 12th May 2016, 02:53 PM   #6
emretelci's Avatar
Thank you. That's ok actually for me. I have tried and all gives a different tone so all are working for me in same circuit without anything...
Old 12th May 2016, 02:56 PM   #7
Merlinb is offline Merlinb  United Kingdom
Merlinb's Avatar
The easiest way to do that with the three (actually two) single-pole relays you showed, is just to have three circuits and switch the outputs. Dunno if you're trying to switch between tubes in the middle of playing though, in which case you'll need cap coupling to avoid pops.
Old 12th May 2016, 02:57 PM   #8
emretelci's Avatar
Thank you very much. I don't think I need to switch all the connections. Actually I don't know which ones to switch to make one tube work only... That's the reason I am asking here to figure out which pins I should switch...
You are right about heaters, I was thinking that. So heaters may stay connected I think, without relays...
Old 12th May 2016, 03:09 PM   #9
i would go with Merlinb's suggestion.
Old 12th May 2016, 03:15 PM   #10
can you give a little more detail as to the heater supply in this pedal?
being that as a pedal the current draw for the tubes would flatten a standard 9v battery pretty quickly wouldn't it?
Switch between tubes with relayHide this!Advertise here!
Power switch driver board(Momentary switch) + output relay board(delayed ON/fast OFF) Neutrality Headphone Systems 1 20th March 2013 11:57 AM
relay switch wiring dscottguitars Instruments and Amps 0 29th December 2012 10:06 PM
Relay or switch mains magnetman Parts 34 21st July 2012 10:03 AM
switch relay question jasong Parts 2 5th May 2005 07:42 AM
Does this kind of switch/relay exist? Hybrid fourdoor Parts 1 3rd January 2004 12:51 PM
