Yet another ECC82/12AU7 Line Preamp
Old 8th May 2016, 10:31 PM   #1
popilin is offline popilin  Argentina
popilin's Avatar
Default Yet another ECC82/12AU7 Line Preamp
As the ECC82/12AU7 is the cinderella of valves, after reading the article of Merlin Blencowe "The Optimized SRPP Amp" I tried this only as a thought experiment
Yet another ECC82/12AU7 Line Preamp-screenshot001-png
The distortion spectrum is just too good to be true
Yet another ECC82/12AU7 Line Preamp-screenshot002-png
Has someone tried this on practice?
In other words: how does it sounds?
I do not suffer from insanity, I enjoy every minute of it. - Edgar Allan Poe
He has the most who is most content with the least. - Diogenes of Sinope
Old 8th May 2016, 10:37 PM   #2
nigelwright7557 is online now nigelwright7557  United Kingdom
nigelwright7557's Avatar
I used a very similar circuit on the front of a solid state amp and it sounded very clean.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 8th May 2016, 11:18 PM   #3
popilin's Avatar
Hi, thanks for your reply.
I have build a lot SRPPs but never optimized it.
There is a small edge on the square wave and I have no clue about it.
Yet another ECC82/12AU7 Line Preamp-screenshot003-png
Reducing cathode resistors the edge disappears, but the output load must be too low.
Old 9th May 2016, 02:26 AM   #4
gofar99 is offline gofar99  United States
Perhaps grid stopper resistors on either the upper or lower or even both sections will help. The basic design though should sound very nice, quite similar to one of mine. I use lower B+ and lower cathode resistors as well. The problem with loading is typical of a single stage like this. I calculate a Z out of about 4K and a idle current of just about 2.2ma. I prefer the sound when the idle current is about 6-7 ma (1/4 to 1/3 of I max for any given tube), cathode resistors of 270R and a B+ of about 220. At those setting the Z out drops to about 2.8K.
Good Listening
Bruce
Old 9th May 2016, 09:17 AM   #5
ruffrecords is offline ruffrecords  United Kingdom
ruffrecords's Avatar
With a 3K3 cathode resistor the tube will be running at a very low current. Do a .op sim to find the current you are operating at. Low quiescent current means low drive capability. You should also know that there is an optimum load for an SRPP that gives minimum distortion. You may just have hit the right value by accident. Also you have a very high HT voltage. One limitation of sims is they do not stop you using silly supply voltages. I once did a sim of an EL84 SE output stage. I tried tweaking the HT and in doing so accidentally added a zero to the HT volts. The performance was amazing. At first I thought i had found a seet spot until I noticed the HT was 3000V!
Cheers
Ian
Old 9th May 2016, 02:58 PM   #6
popilin's Avatar
The SRPP does not need grid stoppers on the upper triode, as the ECC82 has low gm it does not need grid stopper on the lower triode either.
The design is intended to use with an output buffer, so output impedance is not that important.
Cheers
Ian
Hi Ian, thanks for your reply.
The circuit was already optimized using Merlin's equations as a start point and try and error to final tuning, as I said before, reducing cathode resistors output load resistor must be too low and I do not want enormous coupling capacitors.
In fact, quiescent current is too low, about 2.45 mA, but the idea is to use a buffer, be in mind that optimized SRPP needs a fixed load.
Old 10th May 2016, 03:10 PM   #7
2.45mA should be fine for the 18K load. The circuit as it stands should be able to drive about 36V rms into 18K so you have plenty of headroom.
Personally I have never found a good correlation between spice predicted distortion and the actual distortion measured in the circuit. Spice always underestimates distortion and some models are much worse than others. It would be interesting to see some measurements of the actual circuit.
Cheers
Ian
Old 10th May 2016, 04:16 PM   #8
popilin's Avatar
Hi Ian, thanks for your reply, very kind for your part as ever.
Excellent news, this is one thing that I wanted, some information from an expert.
I am tempted to think that the small edges on the square wave are due to some valve capacitances charged/discharged through cathode resistors. What do you think about this? My concern is that a harsh on treble, not audible "per se" due to my tinnitus, would ruin the sound without any clue, like high frequency oscillations.
Cheers
Ian
Unfortunately I only have an old scope and a couple of multimeters, however my experience is different than yours, comparing FFT plots from another friend (Digital scope/audio analyzer) LTSpice predictions was amazing, even comparing a test circuit in Morgan Jones book, LTSpice results was very close to those published in the book. I use Norman Koren models, and that simulation is useful to discard bad models.
Old 10th May 2016, 06:40 PM   #9
45 is offline 45  Italy
45's Avatar
The 12AU7 SRPP was the first valve preamp I made a long time ago but I still have it. At the time B. Aloia was very popular in Italy both for his solid state amplifiers and valve amplifiers. The optimized SRPP with ECC88 was one of his favourite and actually was also used as voltage amplification stage in his later hybrid amp for DIY'ers.
Despite of this I didn't optimize anything and the results were very good anyway, IMHO.
I have found my notes and I measured 1 V r.m.s with about 0.13% THD and 5 V r.m.s @ 1.2% THD. I only needed 0.5V to drive the power amp in the worst case. At 0.5V output THD was 0.08%.
The preamp uses just over 250V supply, 1K cathode resistors for about 4 mA current and 1 uF +1 Meg at the output. Only the bottom cathode is bypassed with 220 uF. The input impedance of the power amp I was driving was 47K and this is what I used to run my measurements. Gain is about 16x, a bit too much but the preamp is usable with no problems.
Power supply needs to be really good.
Old 10th May 2016, 08:45 PM   #10
popilin's Avatar
Hi Pierpaolo, good to see you around here!
You still owe me a picture of your preamp.
On paper, ECC88 seems better for optimized SRPP due to higher mu and lower Ra, but in simulations I still don't achieve so good results.
I have build a lot of SRPP preamps with the ECC82 without optimizing them and they sound very good, however now I want to put the volume pot between the SRPP and a buffer, then lowering the pot thermal noise and reduce greatly fase shifts, that's why I need ultra low distortion.
Yet another ECC82/12AU7 Line PreampHide this!Advertise here!
help with Ecc82/12AU7 selection lightsabre Tubes / Valves 8 1st December 2015 10:49 AM
ECC82/12AU7 Line Preamp popilin The Lounge 357 28th June 2014 05:04 AM
LM3886 + ECC82/12AU7 MilosC Tubes / Valves 17 27th December 2013 04:08 AM
12au7 ecc82 nigelwright7557 Parts 0 29th March 2010 01:07 PM
line preamp using 6SN7 instead of 12AU7 JPS Tubes / Valves 11 23rd May 2007 12:05 PM
Copyright ©1999-2017 diyAudio
