Question about popping Noise - diyAudio
Old 26th February 2004, 06:52 PM   #1
Derrick is offline Derrick  United States
Default Question about popping Noise
I recently acquired a used Audio Valve Assistent 20 Integrated Tube amp with 2 set of brand new RCA tubes. The amp seem to work properly. But every time I power off the amp, it made a popping noise. It's not real loud, but it does pop.
Base on my limited experience with tube amp, I thought this probably caused by a bad tube so I swapped all the tubes out with the second set of tubes. Now, the popping noise went away and reinstate with a little thump noise via the speakers (sort of a small puff of air pressure that push the speaker drivers outward.
Any thoughts or suggestions on what would cause this?
Thanks in advance,
Derrick
Old 27th February 2004, 01:18 AM   #2
diyAudio Senior Member
fdegrove's Avatar
Does this popping occur with the preamp muted or the volume knob turned down all the way?
The recommended turn-of sequence for tube gear is:
- mute preamp.
- turn of amp(s).
- turn of preamp with mute engaged.
- turn of source(s).
Frank
Old 27th February 2004, 05:31 AM   #3
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
I turn off my amps at night all on the same power strip. Works fine. Rarely any popping whatsoever. In any case, the chances are, the power switch isn't adequately bypassed and is causing an HF spike when you open it. This induces voltages in nearby signal wires causing a noise. If it isn't speaker-killing, don't worry about it.
Turning off the preamp first won't do anything. It's in the power amp. Unless you suspect muting the preamp grounds the output, which might have a marginal effect.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 27th February 2004, 09:58 PM   #4
Yes, it still pop with volume down all the way. BTW, this is an integrated tube amp and there is no mute button.
Old 27th February 2004, 10:18 PM   #5
fdegrove's Avatar
As Tim suggests it may be the power switch causing a spark when switched.
To find out just pull out the powercord as a means of powering of.
If that doesn't cause the noise a .047F 250VAC snubber cap across the poles of the switch should cure it.
Frank
Old 27th February 2004, 10:34 PM   #6
ingvar ahlberg's Avatar
The popping might come from the HT caps still carrying tension after the fillament supply is shut down, two ways to go: dont care, not harmfull. (affecting tube life a little but a i suppose this is an EL84 amp and theese tubes live forever, allmost) If to anoying, install bleeder resistors on the HT caps ( if its a multisection cap replace with single caps)
Ingvar
popping and static noise in an Altec 1592A lassoharp Solid State 7 14th March 2009 02:25 AM
Amp causing popping noise? guitarguy12387 Car Audio 7 15th April 2008 01:58 AM
popping noise through 1 channel on Radford STA15 jives11 Tubes / Valves 5 28th September 2007 07:44 PM
Popping Noise = Clipping ? liggs17 Tubes / Valves 5 28th November 2006 07:16 PM
NAD 2400 popping noise Sarge Solid State 3 8th May 2006 12:38 PM
Copyright 1999-2017 diyAudio
