Has anyone used an opamp to split phase for a tube amp?
Old 20th December 2017, 01:18 AM   #91
leadbelly is online now leadbelly  Canada
leadbelly's Avatar
Originally Posted by JZatopa View Post
Follow up question for the group.
Do you think this could be taken to the point of pushing a pair of EL34's or similar tube?
That point was already passed. If an opamp can drive a KT88, it can certainly drive the much easier load of an EL34.
It seems to me like this would be a great way to build a simple and affordable PP amplifier for those who are curious about tubes but don't want a huge investment.
Nope. Don't agree with most of petertub's post, but have to say that driver tubes are typically an already very small portion of a tube amp's cost.
There are still unbridgeable divisions between cultures. How can two peoples ever come to understand each other when one of them is ignorant of Totò? Umberto Eco
Old 20th December 2017, 01:47 AM   #92
indra1 is offline indra1  Indonesia
Hi artosalo, in case that you have missed, Mos57 described a delay related issue of a similar op amp splitter on post #15 newbee-phase-splitter-question which RJM1 offered solution on post #25.
I repost the picture here, bottom schema.
Old 13th January 2018, 02:56 AM   #93
JZatopa is offline JZatopa  United States
Originally Posted by artosalo View Post
Not necessarily, if you want something special.
I wanted to take use of full potential of great 6N6P twin triode. In typical AB1 circuit this can produce some 3 W. With AB2 some 7...8 W is available with very good linearity.
If this were built with tubes only, the circuit would become quite complicated and a lot of glass is needed.
That's a fun looking project, any chance you made extra boards?
Would you be willing to share the power supply schematic as well?
Old 13th January 2018, 09:55 AM   #94
artosalo is offline artosalo  Finland
artosalo's Avatar
I have some extra boards.
There are separate high voltage power supply/regulator board and low voltage regulator board.
Schematic:
Old 17th January 2018, 08:11 PM   #95
PPrabi is offline PPrabi  France
Read my example on page 5
EL84 Push-Pull transconductance amp using smps
Éric.
Has anyone used an opamp to split phase for a tube amp?Hide this!Advertise here!
Split supply, arrangement of gain and phase splitter tubes DrewP Tubes / Valves 4 26th July 2009 04:18 PM
Can I phase split like this? Sherman Tubes / Valves 14 16th June 2007 10:04 PM
Looking for voyd split phase circuit dhole Analogue Source 0 25th March 2005 07:17 PM
Looking for good book about phase split alan_982002 Tubes / Valves 2 28th March 2004 11:43 PM
