Tube Phono Preamps
Tube Phono Preamps
Old 29th March 2016, 02:39 AM   #21
Eli Duttman is offline Eli Duttman  United States
Why don't we see more three stage phono preamps?
I suspect simply because S/N performance with 3 gain stages is substandard.
Allen Wright used split EQ, in a 2 gain stages plus buffer setup.
Eli D.
Old 29th March 2016, 02:57 AM   #22
kevinkr's Avatar
Tube Phono Preamps
Originally Posted by Sodacose View Post
<snip>
Good links though. I don't know about that Muscovite dealio with the batteries and (ACK) solid state devices though
I'm pretty suspicious of the quack that designed those, batteries in audio circuits, what was he thinking.. harrumph..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 29th March 2016, 10:27 AM   #23
piano3 is offline piano3  United Kingdom
If you want CD level output then three stages are needed unless you use a cascode (all valve or hybrid) or high mu valves which may themselves create problems due to Miller capacitance.
Old 29th March 2016, 03:07 PM   #24
rongon is offline rongon  United States
rongon's Avatar
Tube Phono Preamps
Originally Posted by Wavebourn View Post
The one with the 6Z4P(6AU6) pentode DC-coupled to a 6N30P looks very interesting.
Корректор с непосредственной связью
Old 29th March 2016, 03:45 PM   #25
Hearinspace is online now Hearinspace  Canada
Tube Phono Preamps
Just posting this for others who come to this thread because of the title.
The circuit can be built without the jFet first stage for MM. No idea how many have built this but I listened to it for a year or so with a step-up in front and just put in the jFet stage a couple of months ago. Very happy with the results.
Coleman Shunt Cascode RIAA
Old 29th March 2016, 04:48 PM   #26
Mr_Zenith is online now Mr_Zenith  United States
Mr_Zenith's Avatar
Tube Phono Preamps
Great to see this thread pop up, as my next project (I'm currently in the throes of building SY's RLD) will be a proper phono stage. I'll admit to following the "build X to Y dollars" scheme somewhat, as the budget just ain't there for an MC setup - yet.
With that in mind I'm leaning towards Eli's modified RCA circuit, as it seems to have hit the sweet spot between cost, gain, performance and relative simplicity. I've looked at two designs that use battery bias, but I'm not very certain - read knowledgeable - of the designs themselves, nor am I convinced the claimed "performance enhancements" () of battery bias outweigh the added maintenance hassles. I have enough batteries to change/charge as it is! I could be totally wrong on those points, though.
Old 29th March 2016, 04:54 PM   #27
kevinkr's Avatar
Tube Phono Preamps
In my designs the batteries generally outlast the tubes used. I replace at 2 - 4 year intervals. (Some brands of A22/A23 batteries do not seem to last quite as long) Quiet source of bias voltage (floating if necessary) and in the case of mu followers allows for some interesting design flexibility in setting operating points and achieving a high effective load impedance on the driving stage.
Old 29th March 2016, 05:01 PM   #28
Sodacose is offline Sodacose  United States
Sodacose's Avatar
Another take on improving the RCA design:
Sorry, Kevin, it's another outsider
EDIT: Oh, but lookee what else I found in my files.
Nice round values for the parts on that one and 12AX7's are real easy to find. Just bop a guitarist on the head and pick his pockets.
WTF Amps || /r/diytubes/
Old 29th March 2016, 07:49 PM   #29
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Tube Phono Preamps
Pretty standard design, actually. One of my colleagues in Israel who is possessed by anti-capacitance virus designed one with RL only, and an air variable capacitor on input.
Another friend who is more practical designed this one, I think it is a piece of an art:
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 29th March 2016, 08:47 PM   #30
Sodacose's Avatar
Ok, I'll bite Wavebourn. Splain that to the noobs, please.
Did a reverse image lookup and found that one of the time constants is dependent on the cart's inductance (and would only work on MM). I take it that the other two are handled by the resistor divider and bypass caps in the anode load of the pentode?
Have you built it or heard it? I have to admit it's a cool minimalist concept.
Tube Phono PreampsHide this!Advertise here!
Characterizing phono preamps bcarso Analogue Source 24 23rd January 2012 10:33 PM
Advice regarding MC and phono preamps amt Analogue Source 24 11th February 2008 05:26 PM
HELP with PHONO and MIC preamps. P Lazkao Tubes / Valves 10 23rd June 2006 01:42 PM
Phono Preamps JTT Analogue Source 0 1st August 2005 06:58 PM
a little help with phono preamps/cartridges bonsai171 Analogue Source 3 24th April 2004 03:53 PM
