tube buffer for TDA1543 based dac
Old 25th February 2004, 08:17 PM   #11
sparkle is offline sparkle
sparkle's Avatar
Default re
Ups!
I just realized that the schematic is not correct..... bad design..... Sorry
Old 25th February 2004, 08:24 PM   #12
sparkle's Avatar
I just realized that the schematic is wrong. The current that is flowing through the 2k2 resistor is transformed into 3,5V. And I have 3,5V at the cathode of the tube so I must remove 2k2 (and 50k as well) resistor and add the current from the TDA1543 pins 6 and 8 to the current of the cathode resistor and then calculate my resistance of the cathode resistor.
tube buffer for TDA1543 based dacHide this!Advertise here!
My tda1543 based dac (as if there where not enough of them around ;o) hifi Digital Source 21 31st July 2012 03:25 AM
Differential TDA1543 based NOS DAC dsavitsk Digital Line Level 0 6th April 2009 06:41 PM
6SN7 based tube buffer sugano Tubes / Valves 17 23rd May 2005 01:56 PM
Tube buffer on TDA1543? sparkle Digital Source 0 23rd February 2004 07:22 AM
grounds in TDA1543 based dac sparkle Digital Source 7 15th January 2004 07:54 PM
