| diyAudio Sponsor | ||
Hello,
How many plate current of EL509 when bias at -40V? Thank you! |
#2 | |
diyAudio Senior Member
Frank |
#3 |
You been playin with too many triodes... what about screen?
![]() Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#4 |
Sorry.
Plate voltage is 170V and screen connect to anode through 100ohm resistor.(same as Bruce T8 OTL config) Thank you! |
#5 |
Under those conditions a real El509 should show about 40-45mA idle current.
#6 | ||
From their website: Quote:
Frank |
#7 |
Amazingly enough, I have the book. And I don't think it says what typical currents would be. There will be variation for sure, but I think 40mA is a good ballpark number. The T8s are AB, but mostly B.
#8 | |
Wow...Are you reading my mind or what? As it happens I was busy reading your replies to arthur on the Transcendent forum: Quote:
Frank |
#9 |
My friend have a El509 tester (same config as Bruce amp).
I tested 40 tubes, most of them showing 80mA - 130mA at -40V bias, around 7 tubes showing 40mA - 79mA, few tubes showing >130mA. Is it my El509 not real El509? I selected the tubes showing 80mA - 130mA in my T8 amp. Comment, please. Thank you! |
#10 |
these numbers are higher that the few el509s that i've played with, but given normal variation, they don't seem unreasonable.
I think your selection of tubes for the T8s is a good way to choose. |
| Plate current Question | Rob11966 | Tubes / Valves | 3 | 20th June 2009 08:13 AM |
| Plate Current VS Plate Voltage Graphs | Captn Dave | Tubes / Valves | 2 | 13th February 2009 08:57 PM |
| Drive Current for EL509 Enhanced Triode | wrenchone | Tubes / Valves | 55 | 14th February 2006 03:07 AM |
| Welborne 300b DRD plate current | dsavitsk | Tubes / Valves | 0 | 9th September 2005 07:47 PM |
| Russian EL509 / 6KG6 quality question?? | cocolino | Tubes / Valves | 11 | 18th October 2002 10:02 AM |
| Page generated in 0.09947 seconds (82.46% PHP - 17.54% MySQL) with 10 queries |
