Building a Pre-Amplifier
Old 23rd February 2004, 07:23 PM   #1
Joe04 is offline Joe04  United States
Default Building a Pre-Amplifier
Hello, this is my first time posting, and im relatively new in this hobby. I have a Muse Model One Hundred amplifier. I've been looking for a pre-amp, preferably one i could build. I found
http://www.lh-electric.4t.com/sta1.html
Is this tube preamp good quality? (It's the STA1). Also, since i've never built an audio device before, is this a very difficult model to build?
Thanks,
Joe
Old 23rd February 2004, 07:42 PM   #2
Alastair E is offline Alastair E  Wales
Alastair E's Avatar
Default pre-amp
Looks to be a nice straightforward amp should be easy to construct, so long as your soldering etc is up to it!
Das Beste Oder Nichts
Old 23rd February 2004, 09:03 PM   #3
richwalters is offline richwalters
richwalters's Avatar
Hi there...... that Muse Model One Hundred amplifier. What's the input sensitivity for full o/p ?
rich
Old 23rd February 2004, 09:40 PM   #4
Sherman is offline Sherman  United States
I've been looking at this same preamp for a while and have decided to build one also. The specs look pretty good and the price isn't bad either. By the time you add a power supply, chassis, tubes, knobs etc. it will probably be around $150 +, in the same range as the Bottlehead Foreplay.
One thing I've noticed is that it doesn't appear to have an input selector. If you want more than one source connected you'll have to add one but that isn't difficult.
Sherman
Old 24th February 2004, 12:41 AM   #5
Sherman, if you check out their site, for $99.00 you can get the pre-amp AND the power supply. THen, for about $25, they'll ship the tubes.
The link is http://www.lh-electric.4t.com/sta1.html
Joe
Old 24th February 2004, 02:19 PM   #6
The nice thing about their PS is that it is already built. One only needs to add a switch and fuse. But one still ends up at about $150 after the $99 for kit and PS, $25 for tubes, something for an enclosure (Hammond aluminum?) at $15 and knobs.
Still worth it though. My current tube amp doesn't require a PS but I'm considering building both a pair of single ended mono-blocks and a "high power" (15wpc ) pp amp. I'll need a preamp for those.
I actually have all the parts to build a copy of their power supply according to the schematic except a 50mA fuse. When I find the fuse I'll put together the PS from my spare parts and save $50.
Don't touch that, its hot!
Building a Pre-AmplifierHide this!Advertise here!
Building A new amplifier steevo Solid State 0 10th November 2008 06:02 PM
Building a new Amplifier Frank Berry Everything Else 2 29th September 2008 11:18 AM
amplifier building stevecrozz Instruments and Amps 4 18th May 2006 11:16 AM
Building P3A Amplifier Douchekop Solid State 5 3rd February 2004 04:15 AM
Building an amplifier mbates14 Solid State 7 5th September 2002 02:14 AM
