diyAudio Sponsor
Old 23rd February 2004, 05:32 AM   #1
leadbelly's Avatar
Default Any schematics for balanced line driver using 6922?
I think the subject says it all: I have 6922's, I'd like to make a unbalanced-to-balanced preamp for my Aleph-X...any help is welcome.
Oooh, my first post in the Tube forum...fun!
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 23rd February 2004, 05:53 AM   #2
How much gain do you need?
If you don't need gain, many on this forum would suggest a good audio transformer. Jensen is a good place to start.
If you need gain, the design depends on how much you actually need.
Old 23rd February 2004, 06:09 AM   #3
leadbelly's Avatar
I would be happy with unity gain. I know my options in transformers or solid state, so it is not a question of my thinking this is the path of least resistance. I think it would be a great, simple tube project that might just sound wonderful.
Old 23rd February 2004, 03:07 PM   #4
If you don't mind cathode followers (and I don't when they're biased correctly), you can try something like this. It's a simple split load phase splitter driving two CFs as output buffers.
It does need a few different supplies, but they're easy to make.
Old 23rd February 2004, 03:27 PM   #5
leadbelly's Avatar
Thanks! It looks great.
The number of voltages required is a drawback as I was hoping to use transformers out of my parts bin. Would halving all of the voltages (-50, +50, +100) be a bad idea not even worth trying?
Old 23rd February 2004, 07:28 PM   #6
I think that halving the voltages would be sum-optimal, although 6922s don't mind low voltages too much. The performance, especially the THD, will likely suffer.
You can buy 120VAC Triad transformers really cheap. You would only need two of them to provide +/- 100V and the +200V could be had from a voltage doubler. You can even use VR tubes to regulate. 0B2 will regulate at about 108V. Close enough for this amp.
Old 23rd February 2004, 11:00 PM   #7
leadbelly's Avatar
Hmmm, I think I can make do using multiple surplus transformers.
I was planning to use CLC regulation. Is that OK?
And what kind of transformer current draw would I be looking at for 2 channels (3 tubes)?
Lastly, if I only get close with voltages, which would be better: under (-85, +85, +170) or over (-115, +115, +230)?
Old 23rd February 2004, 11:27 PM   #8
diyAudio Senior Member
fdegrove's Avatar
Running every triode on an average of 15 mA would give 6*15 =90 mA without the VR tubes.
Add another 15mA for every VR tube used.
The latter would be far better: don't forget either that the VR tubes need some extra voltage for the gas to ionise ( striking voltage).
Frank
Old 23rd February 2004, 11:36 PM   #9
leadbelly's Avatar
Thanks!
And another thing I just thought of: where would I put a volume control pot, on the unbalanced or the balanced side, and what value?
Old 23rd February 2004, 11:39 PM   #10
fdegrove's Avatar
I'd put a 100K log pot right infront of the 1M gridleak at the input.
Frank
Audio Balanced Buffered Line Driver Quattor Solid State 10 24th October 2005 05:52 PM
is DRV134 the best balanced line driver? anli Chip Amps 4 13th December 2004 06:55 PM
Balanced Line Driver Jerry Parker Everything Else 1 1st April 2003 06:32 PM
Aleph P 1.7 balanced line driver Ignatz Pass Labs 0 31st October 2002 09:06 PM
Page generated in 0.11497 seconds (75.56% PHP - 24.44% MySQL) with 11 queries
