Pioneer SA-81 integrated tube amp
Old 25th February 2016, 11:20 PM   #1
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Default Pioneer SA-81 integrated tube amp
Pioneer SA-81 for conversion to 230v mains and restoration, uses the 7868 tube, contemplating on using the 6L6GC tubes instead...
i am chasing down schematics, pm me please if you have, that will make my work much easier...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 26th February 2016, 01:26 AM   #2
Eli Duttman is offline Eli Duttman  United States
The power O/P of 6L6GCs will overwhelm the O/P "iron". Use 7591s to convert to Octal based O/P tubes, as the 7868 and 7591 are electrically equivalent.
The 7591 family is as easy to drive as 6BQ5/EL84s. That fact was/is exploited by Fisher, Scott, Sherwood, and (at a minimum) me.
BTW, the 6L6GC draws 100 mA. more heater current than the 7591 family.
Eli D.
Old 26th February 2016, 02:02 AM   #3
anatech is offline anatech  Canada
anatech's Avatar
Hi AJT,
Eli is right on the money, exactly on the money. The output iron isn't set up for 6L6 type tubes either.
I have an Eico ST-70 that I'll be restoring sometime. I waited until I found some real 7591A tubes. The 7591XYZ thing did not fill me with confidence. I ended up with 7581EH tubes. See, going the same way you were thinking of going. It wasn't a good path to take. The only reason I didn't use other tubes was that I couldn't find any for reasonable money.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 26th February 2016, 03:41 AM   #4
TonyTecson's Avatar
yes, i have convinced the owner not to do that, we were talking about it on the phone
and when he brought the amp to me, the first thing i noticed right away is the wimpy opt...
but you may be surprised, the same size opt i saw in one of the KT88 offerings from Cayin,
the opt is housed in a box so it is not noticeable until you open up the box...
the 7868 is no slouch either, i remember while in high school, this was the amp we would use during, a diy amp based on the 7868....
i was hoping some one would lead me to schematics so that i will not have to reverse engineer this amp...
Old 26th February 2016, 08:43 AM   #5
JonSnell Electronic is online now JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
From memory, some years ago as a Pioneer main repair agent, the SA-83 is similar.
Pioneer SM-83 Manual - Stereo Integrated Amplifier - HiFi Engine
Hope that helps but is is a very simple amplifier. 6L6 or EL34 will draw too much heater current.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 26th February 2016, 09:33 AM   #6
TonyTecson's Avatar
thanks, the unit that i have is a tad more powerful but the topology could be the same...
Old 26th February 2016, 01:46 PM   #7
anatech's Avatar
Hi AJT,
The 6L6 won't perform as well as it could in that amplifier, but it would work. Your bias currents might be lower, closer to what is used with the original tubes. Otherwise the HT supply may have trouble with the increased current draw for the 6L6 types.
In a more perfect world, you would use the 7591A as it is the same tube that was in there from the factory with a different pin out.
For the customer to go to 230 VAC, it would be the least expensive to use a step-up transformer. I would look at going with one that went from 115 VAC to 220 VAC since the mains voltages seem to be higher these days. 120 VAC to 220 VAC would also give more safety room if the voltages are higher in the future.
-Chris
Old 26th February 2016, 03:41 PM   #8
Remember what I said about the same small signal circuitry being used with "12" W. tubes and the 7591 family. Adjust the B+ rail of the SM-83 and you're looking at the SA-81. Compare Sherwood's S5000 and S5000 II.
I agree with the step up autotransformer idea. However, if a suitable model will fit, a low cost AnTek toroid power trafo could be a reasonable alternative.
Eli D.
Old 26th February 2016, 05:06 PM   #9
lexx21 is offline lexx21  United States
You mean step down transformer....... I would use a variac but that's just me.....
Old 26th February 2016, 06:08 PM   #10
anatech's Avatar
Hi lexx21,
That's post #1.
-Chris
Pioneer SA-81 integrated tube ampHide this!Advertise here!
PIONEER SA-810 Tube Amp Schematics refference Tubes / Valves 18 9th November 2017 11:44 AM
Pioneer SA-9500 Integrated amp- Restoration Project opportunity for someone GordonW Swap Meet 1 12th August 2016 04:21 PM
Pioneer SA-810 tube amp. Archibaldy Tubes / Valves 11 27th April 2012 09:56 AM
Info for Pioneer SA-810 tube amp Archibaldy Tubes / Valves 2 18th April 2011 10:40 AM
Eico Hf-81 Integrated Amplifier orly40 Tubes / Valves 3 7th February 2011 01:44 PM
