diyAudio Sponsor
Old 19th February 2004, 10:07 PM   #1
olvrkrg is offline olvrkrg  Germany
Default cathode follower
Hello,
my question might seem somehow strange. If I would like to drive the cathode of a broadcasting tetrode tube that only allows a cathode - heater difference of 150V with lets say +/- 1000V, the heater somehow has to follow. Can this be done if I heat with accus and connect + and - of the accu through a resistor - lets say 1MOhms - with the cathode??? So all the accu would have to follow the cathode voltage. Any ideas if this could work??
Old 20th February 2004, 08:23 AM   #2
Frank Berry's Avatar
If the filament is "floating" (not grounded), simply connect the cathode to one end of the filament.
A resistor is not needed.
Frank
Old 20th February 2004, 08:35 AM   #3
AKSA is offline AKSA  Australia
Another option, not necessary better but certainly isolating, is to connect a high voltage n channel mosfet gate to the cathode, drain to B+ and source to filament, AND a 100K resistor to ground.
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 21st February 2004, 10:49 PM   #4
Does anyone know what it means for an accu to be connected with a signal +/- 1000V at cathode and anode? I only know that this would influence the electric double layer, but I can't estimate how much current I need to heave and drop the potentials. Does anyone know?
20W cathode follower amplifier yan24 Tubes / Valves 120 3rd January 2009 06:16 PM
cathode follower vlljpior Tubes / Valves 6 22nd March 2005 08:50 PM
Question about direct coupling a anode follower into a cathode follower. G Tubes / Valves 45 29th July 2004 07:47 PM
cathode follower ackcheng Tubes / Valves 2 6th July 2004 04:12 PM
Cathode Follower? Yay or nay? SHiFTY Tubes / Valves 25 16th March 2004 07:38 AM
Page generated in 0.06800 seconds (72.75% PHP - 27.25% MySQL) with 10 queries
