Output transformers - Page 2 - diyAudio
Old 4th April 2002, 03:22 AM   #11
Thatch_Ear's Avatar
If you want to have a transformer that you can saturate and use for distortion a very good source is PA amps. Bogen,Grommes,etc. They were not made for HiFi but for voice amplication. They are common and should be inexpensive, use common tube types and will work great in guitar apps from what I have been told. Also small SE OPT from consoles that had SE for stereo and a PP for bass are great for SE guitar amps. Consoles should be easy to find and cheap to buy. Good Luck!
Thatch
Old 10th April 2002, 05:33 AM   #12
Default Calculation
Hi there,
I have many toroids lying around. May I know how you do the calculation in order to come up with the Primary & Secondary impedances?
Old 10th April 2002, 05:49 AM   #13
Default Calculation
Hi there,
Old 10th April 2002, 04:34 PM   #14
Connect a small AC voltage wall-wart to the primary, measure AC volts in and out.
Impedance ratio will be the square of the voltage ratio.
Old 23rd April 2002, 03:26 PM   #15
Thatch_Ear's Avatar
A great source for outputs that are great for guitars are PA amps from the 50s. As a matter of fact you would just need to overhaul the amp and be ready to go. PA amps usually had output iron set up for reproducing the human voice( limited bandwidth ) and were not very large and so easy to saturate.(not all of them,but the size of the output iron is your guide) Another source are the old consoles as they often had small SE outputs run by 6BQ5s and could easily be put in a 6V6 amp and since they were mostly stereo you would have an extra transformer. Old record players like Rodgers have amps that are about ready to go as is.
Thatch
Old 9th June 2002, 12:13 PM   #16
Circlotron's Avatar
The core of a toroid is wound from a continuous strip of metal like a roll of sticky tape, and so the grain goes along it's length. Tops for trannies.
An EI core has the flux going along the grain then it has to turn the corner and go across the grain. This may be part of the reason they are not as salubrious to sound as are toroids.
GP.
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 10:44 AM
2a3 output transformers.... button_fly Tubes / Valves 3 10th October 2007 02:05 PM
Output Transformers eduardio Tubes / Valves 2 13th May 2005 02:42 PM
Using output transformers on Zen Amp? G Pass Labs 14 5th November 2004 11:54 PM
Copyright 1999-2017 diyAudio
