EF80 push EL153, DIY with a picture tells a story. - diyAudio
Old 12th January 2016, 02:42 PM   #1
TURING is offline TURING  China
Default EF80 driving EL153, DIY with a picture tells a story.
Telefunken's EL153 get our hands there is a feeling of love. 40W power consumption of the anode than his sibling "EL156" summoned up the courage, but has a lower resistance, capacitance between smaller. EF800 EF80 is the long-life models, more precision and longevity. With the EL153, can be described as heroic beauty, good match.
EL153 \ EF80 is a very good performance of vacuum tube, many people can not properly use, resulting in the illusion of high frequency of inappropriate audio use. This article is to teach you how to design, diy, out of a high quality tube amp. And those who disseminate high-frequency tube audio is not well people use the rumor nowhere to hide.
Detailed test results later in this article.
Old 12th January 2016, 02:42 PM   #2
Old 12th January 2016, 02:44 PM   #3
Old 12th January 2016, 02:45 PM   #4
Old 12th January 2016, 02:46 PM   #5
Simulation before the actual production for the successful completion of this tube amp provides the foundation.
Old 12th January 2016, 02:47 PM   #6
JonSnell Electronic's Avatar
Send a message via Skype™ to JonSnell Electronic
EL153 and EF80 both work best as HF/IF valves. Not good at AF.
Support for Flying Mole Class D, Valve Equipment and designs both new and old. www.jonsnell.co.uk
Old 12th January 2016, 02:47 PM   #7
25v EF800 provide impetus voltage is sufficient to promote the EL153. This time preamp distortion of less than 0.3%
Old 12th January 2016, 02:49 PM   #8
Please continue to read on, there is evidence that EL153 is a very good audio power tube
Old 12th January 2016, 02:50 PM   #9
Better at HF than AF. Look at the Data Sheet.
Old 12th January 2016, 02:51 PM   #10
Power supply design is the most important, reduce the AC ripple in the same time, but also to reduce the power resonance amplitude. Here we are using bile rectifier, only to reduce the amplitude of the resonant power to raise more quality sound.
Figure borrowed a transistor as rectifier participate simulation, the actual use of the use of 3DG4, in order to sufficiently rectified current. Double choke design will ripple reduced to -70db or more.
Telefunken EL153 SE circuity TBL Tubes / Valves 21 22nd March 2016 05:59 AM
EF80 vs EF86 newbadboy Tubes / Valves 6 16th April 2014 06:40 PM
My First DIY Loudspeakers [Story & Pics] bmwman91 Multi-Way 22 10th April 2013 08:42 PM
Combine EF80 with EL84 newbadboy Tubes / Valves 27 13th March 2010 05:32 PM
The story of my life: diy speakers (as told by an EE) JLC7 Multi-Way 40 26th August 2008 06:02 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
