Multi Stage amplifier bandwidth.
Old 8th January 2016, 01:47 AM   #1
rlaury is offline rlaury  United States
Default Multi Stage amplifier bandwidth.
With 2 stages cascaded, should the second stage bandwidth be wider than the first?
Some where I read the second stage should be wider by some percentage so that -3dB
points don't coincide at the same frequency to prevent excessive phase shift.
But for the life of me I can't find out the equation.
Anyone know what rules are??
Old 8th January 2016, 07:17 AM   #2
Koonw is offline Koonw
To me if "coincide" means no difference (in phase shift or gain bandwidth product).
Old 8th January 2016, 07:25 AM   #3
I was referring to the frequency. I want to have a single frequency roll off.
Sorry for the confuzion. :-)
Old 8th January 2016, 07:29 AM   #4
No problem. If same freq. roll off it appears the phase shift is doubled (twice as worst) the result is same with my simulator.
Old 8th January 2016, 08:20 AM   #5
DF96 is offline DF96  England
With two stages cascaded the total phase shift is the sum of the individual phase shifts whichever order you put them. To get an early rolloff like a first order filter from two stages you need them to have quite different rolloffs, but the order does not matter.
However, there may be a reason to put the narrower bandwidth one first. This has nothing to do with phase shift but because it is generally a good idea to eliminate unwanted signals as early as possible in an amplification chain. Once a signal has gone it can't create any more trouble, and later stages usually have higher amplitudes so problems can get worse.
Multi Stage amplifier bandwidth.Hide this!Advertise here!
Multi stage on switch RhythMick Parts 7 25th December 2015 07:21 AM
Multi-stage buffer MitchMev Instruments and Amps 14 18th December 2015 09:53 PM
audio amplifier bandwidth davidel94 Solid State 15 4th March 2013 08:30 PM
Amplifier Testing Procedures; Bandwidth and THD mbeards Equipment & Tools 7 14th December 2012 08:00 AM
High bandwidth switching amplifier Snickers-is Class D 22 31st May 2006 05:28 PM
