Tube wiring guide line - diyAudio
Old 29th December 2015, 04:40 AM   #1
cl1238 is offline cl1238  Australia
Default Tube wiring guide line
Hi, is there any guide line for tube socket wiring to PCB?
I'm using a pre made PCB, but the chassis I have does not match up the holes with PCB mount sockets, hence I have to run fly wire to the PCB.
Should the heater wiring must be shielded from the rest (HT, grid, cathode ...)?
Max length of the wires (does the length reduce the sound quality)?
Wire type (24 x 0.2mm, 13 x 0.12mm)?
Old 29th December 2015, 05:05 AM   #2
rongon is offline rongon  United States
rongon's Avatar
Heater wiring should be tightly twisted, so that AC does not radiate into adjacent wiring.
Usually AC heater current doesn't go through PCB traces. Perhaps your PCB was designed for a DC heater supply.
It sounds like your PCB was made for a different tube socket than the ones you have. Why not find the correct PCB mount tube sockets for your PCB? They're usually inexpensive.
Old 29th December 2015, 05:24 AM   #3
Hi, Rongon. if I use PCB mount socket, I have modify the metal chassis (re drill new holes, cover old holes, modify the hole for transformer etc...). It seems to be easier for me just to run fly wire.
Old 1st January 2016, 08:45 PM   #4
That looks like a Douk audio chassis for point to point wiring and the board looks like the one for their other chassis for EL34 output valves. Have you considered doing point to point wiring rather than use the circuit board? it is more flexible so makes component changes easier if you are wanting to upgrade or make modifications. Also helps learn how circuit works!
Old 1st January 2016, 10:12 PM   #5
Thanks Avo, I have already traced the track vs the schematic.
My last tube amp built was 35+ years ago, hence my soldering would be considered as zero, therefore I want to use the PCB to minimise problem.
I'll be connecting the socket to the PCB hence want to know if there are problem when other cables are close to each other (apart from the burner wiring)?
Old 1st January 2016, 10:34 PM   #6
There are a few things to consider, heater wiring does need to be kept separate and neatly twisted to reduce risk of hum pick up. Signal leads are prone to picking up noise so keeping them short is good. Also there are some components such as grid resistors that are best soldered direct to the valve socket as they are there to reduce RF into the valve so if they are portent in your schematic maybe solder direct to the socket and jumper the position on the board.
Things to think about if you have been away from soldering for a hole is that most solder supplied these days is lead free and bloody awful to work with! It is possible to get proper lead tin stuff if you try, I use solder that I have had in my toolbox for over 30 years. Also if using lead free stuff you need a recent soldering iron as it melts at a higher temperature than the old stuff.
Soldering is a bit like riding a bike once you have mastered it you will remember quickly how to do it. I tackled a point to point kit and, once I had decided where to put things, got it together pretty easily and then learned a lot trying to find the not very deliberate mistakes
I guess using a PCB will make misplace,eng of components more difficult the risk of whiskers and dry joints on a PCB is some what higher if you are out of practice.
Best of luck with it I look forward to hearing how you get on.
Caber
Old 2nd January 2016, 12:03 AM   #7
Thanks Caber, I'll let you know once it is finished.
I'll be using my old solder first (hope it is enough for this project) and I'll keep in mind on the new solder characteristic.
Connex Electronics Smart Start V3 Wiring Guide? mstang1988 Class D 1 12th August 2014 06:37 AM
Wiring a line array: altering wiring schemes for matching levels w/woofer dave251 Multi-Way 6 5th February 2014 02:21 AM
Interesting wiring guide find, thanks NASA! m6tt Tubes / Valves 9 26th February 2010 04:57 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
