"The unequal twins" ECC83 / ECC99 Triode and 6N1P / E280F pentode amps
Old 21st December 2015, 08:51 AM   #1
E280F is offline E280F  Germany
E280F's Avatar
Default "The unequal twins" ECC83 / ECC99 Triode and 6N1P / E280F pentode amps
Hallo!
After a long time only reading here, I decided to get a member.
Now I introduce you two of my tubeamps. I hope you enjoy reading this. The amps are not “mainstream”, because they partly use tubes, that are not very often used in tubeamps.
I call them “the unequal twins”, because they use the same enclosure. Electrical they are very different.
The first (my first DIY tubeamp) is a triode SE. It uses a ECC83 in the pre- and the ECC99 (or the 6N6P) in the power-stage. The circuit is reduced to the minimum, as you can see on the diagram. In the power-strage you can use the modern ECC99 or the Russian 6N6P. These tubes are not exact similar. They have different bias settings. So I added a potentiometer to the cathode-resistor. So I can switch between them. In my opinion the 6N6P sounds a little bit better. I have tested it with different output-transformers of 7 kOhms and 10 kOhms. The maximum power is a little bit higher with 7 kOhms, but the in my opinion the sound is better with 10 kOhms.
The sound of the amp is like you expect it from triode amp. Very smooth, but not washed. Always precise, wide and deep, never obtrusive or tiring. I can listen to music for hours without getting rid of the amp.
The only negative is the maximum power output. About 1,1 Watt sine. This sounds very low. I use Heco speakers with a efficiency of 92,5 dB. So the power is enough to listen to music in an adequate Volume and feel the bass “in the stomach”.
The second one is a pentode SE. It uses the Russian 6N1P in the pre- and the E280F in the power-stage. I think the 6N1P is meanwhile known as a very good pre- and driver-stage tube. When you read the datasheet, you can see, that it is a real audiotube, made for low frequencies. Nearly everybody knows the 6N23P, they Russian equivalent of the ECC88. In the last years more and more amps use the 6N1P. In my opinion it is a very good audiotube.
The E280F that is used in the power stage is not knows as an audiotube. You can find some circuits, that uses it in triode-connection as a driver tube. Or as a pentode in pre-amps for record-players. When you read the datasheet, you can see, that is a tube build on a very high technical standard. It was developed as a wideband pentode for industrial proposes, used in measuring equipment and other industrial equipment. Long-life cathode (10.000 hours), frame-grid, very low microphonics and very small tolerances. You maybe ask, why I use this tube in a power-stage of an audio-amp? I can give you a very simple answer for this: A good friend of me gave me 4 pieces of it as a present. After consider a while, I decided to build a tube amp with it.
I also use a very simple circuit for the amp. The E280F has a very high transconductance. So there will be a danger of oscillations. You can solve this problem by using very short wire connections. I additionally used ferrite-pills at the anode, G1, G2 connections. The electrical tolerance of the tube is so low, that you do not need a bias-adjust. I have tested 4 tubes and get 4-times the same results.
I like the sound of the amp very much. It is very precise, extremely wide, deep and detailed.
There is also a little bit negative. The power output is about 1,7 Watt sine. As you can read above, this is enough to hear loud music, if you use speakers with an adequate efficiency.
Maybe you ask, which “twin” I like more? You can use both “for every day”. I like a wide spectrum of music. Jazz, rock or things like BigBand sound a little bit better with the “Triode-twin”. Classical-, electrical music or Hard Rock / Heavy Metal things sounds a little bit better with the “pentode”. But this means not, that you can’t listen Jazz with the pentode-amp or the other way.
I hope you enjoy reading this. I'd appreciate feedback.
Kind regards
Old 21st December 2015, 10:51 AM   #2
petertub is offline petertub  Sweden
What a delight reading this, i very much hope that you continue experimenting
outside the mainline ( by all means build some mainstrem stuff to, comparing
your ideas with some established well-known is never wrong)
I like your open mind. Please continue!
And ,
Frohe Weihnachten
My home is at www.tubular-well.se
Old 21st December 2015, 11:01 AM   #3
On Hiatus
SY's Avatar
Speaking of which... Your pentode amp looks ripe for an inner feedback loop from the output tube plate to the driver cathode.
There's nothing like building and debugging to make a weekend fun!
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 21st December 2015, 12:59 PM   #4
ballpencil is offline ballpencil  Indonesia
Thank you. Good read.
I use the same enclosures on my amps, only shorter. Yours is 20cm while mine is 16cm i think (that sounds awkwardly wrong ). I guess we both love compact amps. Where did you get it? How much? Paid around USD12 for it locally.
Old 21st December 2015, 01:54 PM   #5
lugnut is offline lugnut
Nice read and approach to circuits. I plan on building similar input stages using 6l6/EL34/KT88 output tubes.
Old 21st December 2015, 02:05 PM   #6
ErikdeBest is offline ErikdeBest  Switzerland
Hi SY,
wouldn't ouptut plate to driver cathode cause positive feedback?
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 21st December 2015, 02:17 PM   #7
316a is offline 316a  England
316a's Avatar
Originally Posted by ErikdeBest View Post
Hi SY,
I think it should be plate to plate
316a
Old 21st December 2015, 05:01 PM   #8
Groucho2004 is offline Groucho2004  Spain
I must have entered the twilight zone. Two members, both posting for 12+ years, both having looked at countless tube schematics can't figure out this ridiculously simple circuit?
Old 21st December 2015, 05:58 PM   #9
On Hiatus
SY's Avatar
Hi SY,
Driver cathode is in phase with driver plate. Driver plate is in phase with output tube grid. So.... negative.
Old 21st December 2015, 07:50 PM   #10
I think I got it after some thinking. thanks, erik
"The unequal twins" ECC83 / ECC99 Triode and 6N1P / E280F pentode ampsHide this!Advertise here!
12T10 triode connection - similar "real" triode to compare to? geezertron Tubes / Valves 16 28th February 2015 10:23 PM
Commercial Solid State Amps with jumper controlled Modes "without NFB" and "with NFB" tiefbassuebertr Solid State 12 28th February 2014 04:27 PM
E280F Triode mode operating point frankmalz Tubes / Valves 2 20th July 2013 09:50 PM
Using a standard pentode-tetrode as output "space-charge tube" any ideas-experiences? bembel Tubes / Valves 12 11th March 2010 05:56 AM
My "Twins" (AR.com aka EFE Kit) Visor57 Multi-Way 2 15th September 2006 06:09 AM
Copyright ©1999-2017 diyAudio
