WARNING: Tube/Valve amplifiers use potentially LETHAL HIGH VOLTAGES.
I can see that it's an OPAMP classic current source but I can't figure out what is zener D3 for.
Picture doesn't show but it's a classic triode preamp B+ regulator.
Looks like some kind of clamp to me, perhaps to prevent latchup under certain conditions and/or simply to protect the opamp inputs being pulled above or below the opamp supply voltage.
you are both right, thank you.
You put me on the right path. So, I found some explanations about this opamp's behaviour. But the protection recommended is by schottky diodes.
So, why a zener is used here ?
A zener allows the voltage across the diode to reach the value of the zener. Using a standard type diode would clamp the voltage across it at a permanent 0.6volts and not allow any voltage swing. The zener allow swing up to the zener voltage.
