Google Eico St70, manual appears to be downloadable.
Eico ST-70 Manual - Stereo Integrated Amplifier - HiFi Engine
I need a Eico st70 construction manual.
Post a close photo of the bottom of the chassis. There are lots of switches in the signal path.
If you don't need those functions, eliminating those and the associated wiring would be worthwhile.
Same for the tone controls if you don't need them.
Hey guys,it looks to be a complete unit came with all original tubes, I've done a recap, lots of resistors were way out of spec ,changing them out one at a time. My plan is to get it working as original, I want to seperate the sections.. I want the amplifier for midrange duty only. I'm building a set of triamped speakers. Separate the phono preamp never owned a tube phono pre. I have a general idea where to separate things , if needed ,not sure where to put resistors or caps after the separation. Maybe it will sound so good ,I'll leave it original and start a second system...
Google : Hotroddingthe Eico ST-70.
I've a pair of it's output transformer and am undecided what other design to go with!
That's pretty good "iron". You could try Williamson style circuitry and 6П3С-E (6p3s-e) O/P tubes. Antek's AS-3T325 looks like a good place to begin a PSU.
- Tubes / Valves
- Eico ST70 construction manual...
