"rejuvenate" oxide cathode - diyAudio
Old 16th December 2015, 08:54 AM   #1
kaputt is offline kaputt  Germany
Default "rejuvenate" oxide cathode
Hi! I pulled a Taylor 866 from my stash and noticed at heating up that the cathode was only glowing properly at the ends ands was darker in the center. I then hooked the heater up to a benchtop PSU and saw it only draws 3.8A. Usually they draw around 4.6A (datasheet states 5A).
Leaving it heated didn't change much.
Is there a way to get the resistance of the filament down or is that one done for?
I like "effects boxes". As long as the effect is the right one.
Old 16th December 2015, 09:08 AM   #2
DF96 is offline DF96  England
I think all you can do is boost the heater voltage by a little, but that will only be a short term measure.
Old 16th December 2015, 09:35 AM   #3
JonSnell Electronic's Avatar
Send a message via Skype™ to JonSnell Electronic
May be a silly question but is the heater voltage correct?
Support for Flying Mole Class D, Valve Equipment and designs both new and old. www.jonsnell.co.uk
Old 16th December 2015, 10:21 AM   #4
Hi Jon, heater voltage was correct.
The ubiquitous 1/2"...um....3/4"...er 1" ?? polycarbonate "dome" tweeter River757 Multi-Way 16 8th July 2013 12:45 AM
PP CATHODE BIAS WITH "CCS" tim614 Tubes / Valves 42 8th April 2013 11:55 PM
3-way with big (10") woofer and monitor (6.5"+1") on top like "Tarkus" proxii Multi-Way 16 30th October 2012 12:43 PM
Power Tube Cathode Resistor "distance" M Gregg Tubes / Valves 7 9th March 2011 10:37 AM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
