Classi RIAA preamp questions
Hego, did you use the ZVN0545A MOSFET called for? FETs with large reverse transfer capacitance roll HF information off.
What Eli said! I've used the ZVN0545A in a couple different preamp circuits and the results have been EXTREMELY good.
The higher the current through the ZVN0545A the higher the Gm too. So I ran it at about 3.5 ma. with 115 or so volts on the source.
Try that circuit again with that specific MOSFET and see if you don't get better results.
Hello folks,
Sorry to dig out this thread.
First of all: The RIAA preamp works and sounds very fine now. Unfortunately it hast to much gain! I measure 45dB@1Khz and want to have only 40dB. I tried some other tubes (JJ Ecc83S, JJ ECC803S, Sovtek 12AX7LPS, Shuguang 12AX7B ) but there is only negligible difference.
The big question now is: How to reduce the over all gain to 40dB@1Khz without to hit the RIAA EQ?
I try to use a feedback resistor from C6/R9 to gate of first stage. This seemed to work but the low fequencies are dropped down ( if I can trust LTSpice simulation ). To reduce noise it make sense to reduce gain on first stage..
Any idea?
Thanks a lot,
Karsten
  • RIAA-Tube.asc
Hello folks,
Any idea?
Thanks a lot,
Karsten
If you can find them, you can try 5751 (old GE 5-star tube) which has mu of 70 instead of mu of 100.
What's wrong with 45dB of gain? What cartridge are you using? Maybe your cartridge has higher gain than most.
Disabled Account
Joined 2013
There are 2 caps missing see attached. The sch should work with no further mod. Bias is added for sim purpose only.
  • RIAA-Tube-2.asc
Hello everyone,
I am an unconditional power triode is my Blogg: Officina Tron-audio Switzerland
you will find a section with DIY describing a multitude module dedicated to audio.
as here for a map RIAA Phono MM / MC dedicated: Officina Tron-audio Switzerland: Préamplificateur Phono MM/MC
or here (under construction) with the description of an optimized phono Marantz replica card: Officina Tron-audio Switzerland: Préamplificateur phono MM Marantz Replica
I let you watch and read and if you want more information you can contact me via blogg or so more directly here: antony.turchi@tron-audio.ch
Best regards. Tony
Dear Koonw
Thanks a lot and bow down!
I do not add the both capacitors in simulation because I thought it´s not relevant for simulating.
Increasing the kathode bypas capacitor to 470µ will improve the bass response up to 0.5dB wich is quite linear after this modification.
I played a little bit with bias of the second system and set it now to 1.33V using a kathode resistor of 1K9 and a bypass capacitor of 1n8 to improve high frequencies between 10Khz and 20Khz.
Now it looks very linear and has an over all gain of 39.8dB which is more than exact for me. Now lets move the simulation to reality...:)
Thanks a lot for your simulation modification especial the reverse RIAA!
best regards
Karsten
Joined 2004
It's improper assumptions.
Without these capacitors your anode resistors is: R5+R4, and R6+R3, thus RIAA calculations will be wrong.
Moreover first stage B+ voltage is modulated with I(U2)*R3 voltage.
This is my (5751) phono. As you can see, correct filtration and separation is very important for phono stages.
