Claus Byrith 4-30 - HELP ! - diyAudio
Old 10th November 2015, 05:39 PM   #1
sunil is offline sunil  India
Default Claus Byrith 4-30 - HELP !
I plan to attempt this design. In the PS stage there are two components I don't understand.
0.2AF - ?
2AT - Is the the fuse rating ?
A friend is helping build it. He is good with 'Audio' technology and we're designing the build at this stage.
Thanks.
Old 10th November 2015, 05:41 PM   #2
Default The published power supply
The power supply.
Old 10th November 2015, 06:08 PM   #3
vega65 is offline vega65  Norway
yes fuses
Old 10th November 2015, 06:18 PM   #4
GoatGuy is offline GoatGuy  United States
GoatGuy's Avatar
AF is “amps, fast blow” or fast reaction time
AT is “amps, standard blow”, good for power lines and such.
AS is “amps, slow blow”, having extended over-current surge capacity.
AS is good for motor-startup, for instance. Always way-more current flows while the thing starts to turn over. Then it levels out. You wouldn't want to be blowing fuses every time you nominally start a motor.
GoatGuy
John Curl's Golden Rule…: 100 kHz bandwidth, 3 μs risetime, 100 W mean output, 100 V/μs slew rate, 2 Ω dynamic load, 20 amp min current source/sink
Old 11th November 2015, 06:45 AM   #5
Thank you vega65 and GoatGuy.
Any recommendations, modifications, suggestions ?
Old 11th November 2015, 07:01 AM   #6
Suggest you build it as pr the manual first , later you can look into mods if you like.
( a ccs below the ecc83 cathodes might be woth trying)
Old 13th January 2016, 12:25 AM   #7
Is my reading correct - separate 100v power supply for the negative voltage.
Old 13th January 2016, 02:51 AM   #8
Also substitute UF5408 diodes for the 1N5408.
1N5408 have amongst the worst switching noise I've ever observed.
That switching noise will couple back thru' the power tranny into the -ve bias supply and the heater supply.
Similary use UF4007 instead of 1N4007.
Ian
Old 13th January 2016, 08:36 AM   #9
Thanks for the tips Gingertube.
So, is that separate -100v supply corrrect ?
Old 13th January 2016, 11:48 AM   #10
yes , I can check the value of Rvg1 I used.
Claus Byrith 4-30: missing valve in the PCB? jlbm Tubes / Valves 2 5th June 2015 07:31 PM
Tube amp instability in LTSpice (Claus Byrith 4-30) PsychoM Tubes / Valves 26 27th February 2015 12:38 PM
Claus Byrith 4-30 PP with KT66 kxden Tubes / Valves 0 30th September 2013 10:12 AM
Claus Byrith 4-30 Questions Mike L. Tubes / Valves 2 24th August 2007 02:11 PM
Using the Crowhurst articles and Claus Byrith eddog Tubes / Valves 8 16th February 2006 09:11 PM
Copyright ©1999-2017 diyAudio
