01A question
01A question
Old Yesterday, 12:31 PM   #411
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Originally Posted by Rod Coleman View Post
Grid bias should be better still, especially in terms of low distortion, but some don't like the grid capacitor. The Russian teflons sound fine to me in this position, but that's a matter of taste....
Rod could you post the schematic for 26 or a link?
TIA
Felipe
Originally Posted by andyjevans View Post
We have been auditioning many resistors. My favourite, displacing the otherwise good vitreous enamel ones, is a military wire wound one from Russia in a silver colour.
Filament supply is always an issue, as you say. I always use choke input for that reason - it's smoother.
Andy do you remember the reference of russian wire wound silver colour?
TIA
Felipe
Old Yesterday, 02:34 PM   #412
pcgab is offline pcgab  United States
01A question
TIA
Felipe
I'm fairly certain he is referring to the 'S5' type, looks like 'C5' on the resistors themselves.
51 Ohm 10W Russian Precision Wire Wound Resistors 18 pcs | eBay
Gable
Old Yesterday, 02:40 PM   #413
andyjevans is offline andyjevans  United Kingdom
Yes - those are the ones.
Old Yesterday, 04:36 PM   #414
jhstewart9 is offline jhstewart9  Canada
jhstewart9's Avatar
How does one audition a resistor? What properties do we test for?
Old Yesterday, 04:58 PM   #415
Well, we all listen in different ways so I can only speak for myself. Resistors, or any parts in fact, always get auditioned in the same way. I was a working professional musician for 15 years, classical, orchestral, jazz, small groups etc. I have an excellent memory and the timbre of each instrument is stored in my memory. I listen for just 2 things - timbre and transparency. First it's a question of what you can and can't hear in a complex mix, and then it's a question of how authentic the timbre of each acoustic instruments or voice is. So typically I'll use a heavily scored orchestral excerpt, for which I use Ravel Feria (Cleveland/Boulez) plus an excerpt from an opera with a few different voices plus chorus, for which I use Janacek's Cunning Little Vixen. A large number of different timbres, and some very low level detail. That's it.
I imagine you are referring to electrical properties, and if I had the measuring equipment and the training in using it I'd love to answer that question. But my training is in the music itself - 3 years conservatoire and 15 years of live gigs. After my career as a musician I've been a psychologist specialising in musicians for 30 years. Since psychology is heavily into measurement and data analysis I'm the last person that's going to belittle measurement of any kind.
Old Yesterday, 05:56 PM   #416
hpeter is offline hpeter  Slovakia
hpeter's Avatar
Here is the info on a DH amp I built a while ago. Notice lots of performance data.
This amp has none of the warts I see others having problems with in this thread. It is not a rat's nest of wire in a wooden box, something that invites trouble in.
But the 1B5 is microphonic!
thanks for the dht info, i didnt knew that neat one
BLOG. XMOS_U8/PCM5102A > LL1544A > 6H9C+gyrator > 2A3_SOV/JJ > LL1660 > STAX SR207 _ SR L300 _ SR007 # LL2748 > 394A > LC 12H/1000
Old Yesterday, 07:42 PM   #417
Gable
Many thanks guys.
Old Yesterday, 08:28 PM   #418
jhstewart9's Avatar
OK Andy, thankyou for the a description of that method. And you are correct, I'm looking at the problem from an engineers point of view. I'm very results driven, I like to see things get done in a timely & professional way.
I've been building amps & other electronics for more than 70 yrs. But never my day job. I will be 86 in a couple of wks. But other than failures for one reason or another I've never experienced any serious problems with the linear components, Ls, Cs & Rs.
The distortion from the tubes & transistors has always dominated, so long as care was taken in selection of the other parts. Output transformers & electrolytics can cause problems as well.
I did take the time to consult my Funk & Wagnalls Dictionary in regard to definition of 'euphony', a term used by many in these threads. From that I believe quite a bit of the sound you & others analyze by ear can be measured. With existing equipment.
I like Classical & Jazz. But Rock too. The Rolling Stones, Pink Floyd, ZZ Top, Phil Collins & on & on. I have a large collection of vinyl & CDs. My dayly driver is a Sansui AU717/TU717 combo. And in the workshop, Eico AM & FM tuners. Going thru my home grown complete 3W amp with phono front end, all in a Hammond chassis. That one built in 1968.
Old Today, 06:21 AM   #419
indra1 is offline indra1  Indonesia
OK Andy, thankyou for the a description of that method. And you are correct, I'm looking at the problem from an engineers point of view. I'm very results driven, I like to see things get done in a timely & professional way. ...
Correlation of measurement to listening impression are rather esoteric and scarce. The effort requires sensitive equipments that used to be insanely expensive and at least one sensitive listener.
As an example, XRK971 in AKSA's Lender Preamp with 40Vpp Output did find a measured difference of 0805 smt thick film (first mistakenly referred to as metal film and later corrected to thick film) and carbon composition exclusively on feedback position at -90 to -100dB, however no correlation to sonic presentation.
Spread thinly here in Diyaudio forum, I noted findings of correlation of frequency response, distortion spectra and phase of second harmonic to sonic presentation by notables such as Nelson Pass (and Joe Sammut), John Curl (and Bob Crump), highly respected teams, and the late Charles Hansen who had the very rare combination of both exotic equipments and sensitive hearing. Other findings in Diyaudio I value is the coordinated effort of Alejandro Moglia, Andy Evans and Rod Coleman.
However, dbt result from panel of experienced listener is needed for the findings to be accepted by the AES (in which nobody cares to finance), hence the scarcity of official publication.
01A questionHide this!Advertise here!
6V6 / 6AH4 / 01A (UX201a) juanitox Swap Meet 0 26th May 2013 05:42 PM
01a DHT Preamp mogliaa Tubes / Valves 0 13th May 2012 10:07 AM
01A tube amp Schematic??? jmillerdoc Tubes / Valves 4 29th December 2009 01:39 PM
Can I use a 01A in a headphone amp? sbelyo Headphone Systems 27 28th April 2006 11:33 AM
questions about 01A / 483 pre-amp. RichJones Tubes / Valves 0 11th September 2003 08:46 PM
