Coupling capacitors
Coupling capacitors
Old 29th October 2015, 08:53 AM   #1
sb****33 is offline sb****33  France
Default Coupling capacitors
Hello everybody
I'm just curious about the values in this preamp : C4-C6 .22uF.
Why not 10uF like the output one C7 ?
Are they acting like low frequencies cut-off ?
There are such value in ARC SP6, for exemple.
Old 29th October 2015, 09:14 AM   #2
R.I.P.
the coupling capacitor acts as a High pass filter when combined with the following load.
The load is 1Meg in parallel to the grid input impedance.
I don't know how to calculate that input impedance.
If I assume it is 0.5M , then the total load after the coupling capacitor is:
500k*1000k/(500k+1000k) = 333k
The turn over frequency of this single pole filter is given by
F-3dB = 1 / (2 PiRC) = 1/(2*3.14*333k*220*10^-9) = 1/0.46 = 2.2Hz
The response will be down by ~1dB @ 4.4Hz
You need an estimate of the input impedance to allow you to check the F-3dB.
regards Andrew T.
Old 29th October 2015, 09:16 AM   #3
R.I.P.
Your profile says you joined in July 2001, but under your nickname it states Jan 2009
What up?
regards Andrew T.
Old 29th October 2015, 09:39 AM   #4
ErikdeBest is offline ErikdeBest  Switzerland
mostly thinkerer
Coupling capacitors
What up?
Weird indeed If one clicks on profile, the name Stan 33 something appears, with last activity in 2006.
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 29th October 2015, 11:12 AM   #5
OK, Andrew.
What about C6 and C7 ?
Old 29th October 2015, 11:17 AM   #6
What up?
what nickname ? stan_33 ? I don't know who is it. I never entered that name.
Old 29th October 2015, 11:24 AM   #7
DF96 is offline DF96  England
I seem to recall other people finding that the site software can confuse people with what it considers to be similar IDs. stan_33 and sb****33 both start with 's' and finish with '33', so easy for a dumb computer to think they are the same person!
Raise a query in the web problems forum.
Old 29th October 2015, 11:31 AM   #8
R.I.P.
is "****" appearing because he typed ****, or because the Forum recognises that as a banned word and has overwritten his entry?
regards Andrew T.
Old 29th October 2015, 11:36 AM   #9
R.I.P.
C7 is coupling capacitor, but the output looks wrong.
C6 is a bootstrap that creates one of those totem pole thingies that I don't understand.
regards Andrew T.
Old 29th October 2015, 12:05 PM   #10
Merlinb is offline Merlinb  United Kingdom
Merlinb's Avatar
R2 is incorrect. It should be much larger, say 100k to 1Meg.
Coupling capacitorsHide this!Advertise here!
Coupling capacitors ChristianThomas Solid State 12 17th May 2012 01:06 PM
The effect of different value coupling capacitors? paulluvsmusic Tubes / Valves 10 13th November 2011 11:49 PM
Coupling capacitors lazzer408 Instruments and Amps 20 12th November 2011 05:19 PM
AC coupling capacitors... Frazzled Solid State 8 30th June 2004 06:28 AM
