Can I use LT1083 as a CCS load?
Old 13th February 2004, 05:13 AM   #1
mrstone is offline mrstone  Hong Kong
Default Can I use LT1083 as a CCS load?
Hi Folks,
If I connect LT1083 as a CCS, could I use it as a CCS load on tube preamp circuit?
Thanks so much!
Mr. Stone
Mr. Stone
Old 13th February 2004, 08:03 AM   #2
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Sorry, but it would be terrible. A CCS for an anode load needs to be almost as good at 20kHz as 20Hz. None of the IC regulators are any good at 20kHz. They were designed for high current (1000mA) DC use rather than optimised for AC performance while passing perhaps 10mA.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 13th February 2004, 11:00 PM   #3
redwine1118 is offline redwine1118  Hong Kong
Send a message via Yahoo to redwine1118
U can try a tube CCS 7H-4B for preamp circuit
Old 4th September 2004, 08:38 AM   #4
Mikewong is offline Mikewong  Italy
How to connect 7H-4B to be used as a CCS for a preamp tube?
Old 5th September 2004, 06:08 AM   #5
hacknet is offline hacknet  Singapore
what about a CCS on the cathode?
Old 5th September 2004, 05:22 PM   #6
Dear Mike,
If you want to have the idea on CCS 7H4B, please provide me your e-mail. The cct. diagram is under the copyright of a website.
Old 7th September 2004, 10:55 AM   #7
Thanks for the kindness of redwine1118 sending me the schematic which showed CCS as used for tube's heater
whereas my concern is how to use 7H4B as a CCS for the tube's anode.
Old 7th September 2004, 11:27 AM   #8
tubetvr is offline tubetvr
Sorry but a constant current regulator of this type is much too slow for this purpose, the reaction time can be measured in seconds so the bandwith is less than 1Hz!
These regulators consist of a wire of iron in a hydrogen gas, if current should when the wire gets warmer and the resistance increases so the current decrease aso until it stabilise at a certain value. An ordinary lightbulb have the same function but the current is less constant.
Regards Hans
Can I use LT1083 as a CCS load?Hide this!Advertise here!
LT1083/LT1084 Regulator uhcmos Swap Meet 18 6th August 2008 05:46 PM
Problem with LT1083 PSU... Dxvideo Power Supplies 6 12th June 2008 01:48 PM
LT1083 PCB or project files available? luvdunhill Power Supplies 2 21st February 2008 06:47 PM
LT1083 Oscillating Bassterror Chip Amps 5 13th February 2007 09:42 PM
LT1083 Output Impedance thejohn Chip Amps 0 31st October 2005 08:15 AM
