Vinyl Savor 6CB5A SE Amps?
I recently built my first tube amplifier a 6EM7 which is a television tube and I thoroughly enjoyed the sound. I started considering building a better tube amplifier and thought maybe a 300B amp but the prices for these tubes are outrageous on my budget. I proudly admit that I am a cheap Diy'er. After searching the web I came upon Vinylsavor's web page and did some reading. I like the fact that the 6CB5A's are not expensive and Thomas states the amps he design can and do sound better than many 300B amps. I decided to build one of his cheaper designs, this one.
VinylSavor: Single Ended Amplifier Concept, Part 4
The closest transformer I could find with the specs he specifies was a toroid from Antek.
AS-4T320 - 400VA 320V Transformer - AnTek Products Corp
This transformer has dual voltage sources so I decided to build separate PS so in effect I would have mono amplifiers using a single transformer. A 10Hy choke gets pricey and as I have stated I am a cheap Diy'er so I chose to use a 6Hy Triademagnetics C-14X you can purchase for $15 and for 2 PS the cost is $30. I used one in my 6EM7 build and it was very satisfactory. I used Edcor for my OPT's specifically the GSXE15-8-3.5K. Later I noticed Thomas recommends using a 5K OPT but I found this out after ordering. It sounds great with the 3.5K though. I used my first PIO Russian coupling capacitors and other than these changes I built it as per schematic. I just finished it yesterday so I cannot give a review yet but first impressions are very positive. It has great authoritative bass much as a SS amp and a great holographic sound stage. The tubes have no hours on them and the sound is amazing from the first listening and one of the first things I noticed is how quick it is, good transient response. I am going to do some more listening and will give more of a review later. Many thanks Thomas Mayer for making this amplifier available for DIY'ers.
I am considering changing my amp over from a coupling capacitor to a interstage transformer but would like to buy it in the USA preferable from Edcor whom I use frequently. The specs call for a 1:1.125 10 milliamp. Can anyone point me in the right direction?
Hi
The 126C from Hammond (1:1, 15mA, about 100H) could work as well in this design - is "made in Canada" ok? Still, Edcor will surely make you something nice as well, but asking for 1:1.125 will surely be a custom job which costs some $$ extra. So, to stay cheaper, just ask them if they have a 1:1 project ready: the 12% difference in ratios is barely audible (if my math is right it is about 0.98dB.
erik
as you are in the US, Lundahls can be bought from K&K audio (price for a single LL1660 is 125 USD)
K&K Audio | Prices
Indeed, the LL1660/10mA does have a bit more H than the Hammond (datasheets state 130H vs 106H), so the Lundahl would do better in the bass. OTOH, the Hammonds 106H is at 15mA DC - the H will go up a bit if you run only 6 to 7mA.
If budget is not a problem I would go for the Lundahl. Member Andy compared both and liked the Lundahl better, besides the Lundahl is way more flexible for a possible future project (can be used for line out, OPT for high impedance - >300R - headphones, even as PP to PP interstage).
Cheers, Erik
Thanks everyone for explaining what is needed. I must admit that I had a sticker shock when I found out what was needed. I am a relatively new tube builder and interstage transformers are something I knew nothing about. What could I expect in improvement of sound using transformers vs capacitors. I have heard that it would be an improvement but not much on what exactly would be improved. Mine sounds better than any amp I have ever used with my horns just using a capacitor.
Hi!
If you are thinking about merely sticking a interstage transformer in the existing circuit, I would not recommend it. Better to adapt the IT coupled circuit which I posted. The IT-coupling is just one part of the game. The difference in sound will depend on the quality of parts, power supply and especially ITs.
Best regards
Thomas
I thought as much and if I decide to try an interstage transformer amp it will be a totally new build using the other schematic. It would be virtually impossible to put those big transformers in my present build. This amp sounds so great as I have built it that I would love to hear a better version though. The interstage amp build is definitely going on my bucket list.
Thanks again Thomas for publishing these builds.
I finished this amp a couple of weeks ago. It has about 6W. it is connected to small B&W 805 Signature speakers with REL woofer. Sounds quite well despite the fact that the speakers are insensitive (89dB producer claimed).
Yesterday I decided to hook it up to my B&W 802D out of curiosity. This is a 93dB (producer claimed) but very difficult to drive as it has a bumpy impedance curve. What I'd say? This amp is a real fighter! :)
Of course, it sounds as if it needs more power but there was music, and it was good :) And it was quite loud.
